586,540 active members*
2,990 visitors online*
    Jan 2009
    40
    Tool unclamp noise
    Hello.
    I have a problem whit the toolchange in a MA40HA. It seems like the tool is not unclamped fast enough. The arm sometimes drags the tool out from the spindle whit a banging noise. I have taken the cylinders apart and checked the springs and the draw bar. It did not help. I bleeded the system and there seems to be no air in the hydraulic oil. The problem is present even whit a low tool change speed (25%).
    Are anybody having a idea what the cause could be?
    Could the hydraulic valve work too slow?
    Thanks for any help!
    Best regards, Samuel
    Apr 2024
    4
    Re: Tool unclamp noise
    Call a engineer, some of the MA40H has 2 stage unclamp cylinder, and a some of them has really difficult hydraulic system..
    also inside drawbar there a some ruller pins, that rust.
    My suggestion if yu are not sure about the mechanical parts then call local service.
  1. Tool unclamp / drawbar sensor
    By mishikwest in forum Haas Mills
    Last Post: 01-30-2021, 01:34 AM
  2. Spindle Tool Unclamp Timeout
    By Ph2011 in forum Bridgeport / Hardinge Mills
    Last Post: 10-19-2012, 01:57 PM
  3. mazatrol tool unclamp
    By bigbobr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-04-2012, 02:48 PM
  4. Tool clamp/unclamp via Focas
    By Danijel in forum Fanuc
    Last Post: 01-14-2011, 08:43 AM
  5. Tool unclamp fault
    By IMlearnin in forum Daewoo/Doosan
    Last Post: 06-08-2007, 02:40 AM
