586,648 active members*
2,893 visitors online*
    Apr 2024
    CNC machine identification
    Hey All,
    I am looking for some help in identifying this machine. We believe it is used to make crankshafts and might have an internal cutting area of about 1.75 meters.
    Thanks yall!
    Attached Thumbnails Attached Thumbnails CNC machine identifcatoin.jpg   large bore crank shaft cnc machine.jpg
    Re: CNC machine identification
    Quote Originally Posted by bkfta1190 View Post
    Hey All,
    Thanks yall!
    You forgot to attached the machine photos?
    Apr 2018
    133
    Server problems resulted in the images not transferring to CNCZone properly, so I added them here:
    Attached Thumbnails Attached Thumbnails Capture3.jpg   large bore crank shaft cnc machine.jpg   CNC machine identifcatoin.jpg
    Apr 2018
    133
    Attached Thumbnails Attached Thumbnails large bore crank shaft cnc machine.jpg   CNC machine identifcatoin.jpg   Capture3.jpg
    Apr 2024
    hey right on man, thank you a ton!
