586,969 active members*
2,917 visitors online*
Results 1 to 16 of 16
Hybrid View
    Dec 2006
    16
    Planet CNC ATC Script
    Hello. Is there someone who can help me with Carousel type ATC. Ive been struggling along for weeks with this. I have fitted a carousel type ATC to my mill running Mk3/9
    The corousel is driven by servo motor.
    If im correct in my thinking, once the carousel is homed and at position 1, the rest of the tools will be at a certain degree of rotation of the carousel? So for a 12 position carousel that would be every 30 degrees? Sounds pretty straight forward unless im over simplifying this? If this is indeed the case, what im having an issue with is in the tool table theres only options to assign XYZ to the tool. No option for rotary axis in degrees? Ive searched the internet for weeks and find very little info on planet cnc with carousel. Found a video with a geneva drive (not rotary) and a video in German which ive looked at over and over and cant make sense of. If there someone who can shed some light id be truly grateful
    Thank you in advance
    Mar 2017
    1325
    Re: Planet CNC ATC Script
    You cam modify M6 script to add carousel rotation.
    Dec 2006
    16
    Thank you. Yes i figured that, but dont know how to modify script. Thats exactly what i need help with. Maybe if i can see a working M6 script with carousel so i can get an idea to modify for my use....
    When i look at default M6 script i dont see anything about carousel
    Mar 2017
    1325
    I recommend taking a look at the M6 script file code, and locate the "Move To" section. Here you can add the move lines of gcode for your A axis.
    Guide on how to access script code:
    https://cnc.zone/kb/tutorials/easy/how_to_edit_built-in_script_files
    Dec 2006
    16
    Thank you for reply. I tried this. I added tool at top of script and at the point in the script "Move To" I added the line G53 G00 A#<tool>
    So that seems to do something right. When i run the script the A axis moves to "20". But now how do I add other tool locations? I tried adding a tool at A=40 as below but how to point to that in script when tool No.2 is called?
    #<tool> = 20.000 (Tool No.1)
    ;#<tool> = 40.000 (Tool No.2)
    o<chk> if[LNOT[ACTIVE[]]]
    M6
    M99
    o<chk> endif
    o<chk> if [LNOT[#<_tc_enable>]]
    M6
    M99
    o<chk> endif
    o<PlanetCNC> if[[#<_tc_toolmeasure>] AND [#<_probe_pin_1> EQ 0] AND [#<_probe_pin_2> EQ 0]]
    (msg,Sensor is not configured)
    M2
    o<PlanetCNC> endif
    M73
    G17 G08 G15 G90 G91.1 G90.2 G94
    M50P0
    M55P0
    M56P0
    M57P0
    M10P1
    M11P1
    (print,Toolchange)
    #<toisset>=0
    #<wstarta> = #<_a>
    #<wstarty> = #<_y>
    #<wstartz> = #<_z>
    #<spindle> = #<_spindle>
    o<sp> if [#<_tc_spindlecheck> AND [#<spindle> NE 5]]
    (print, Spindle is ON)
    M5
    o<sp> endif
    o<st> if [#<_tc_skipsame> AND [#<_current_tool> EQ #<_selected_tool>]]
    (print, Skip same tool)
    M99
    o<st> endif
    o<sh> if [#<_tc_safeheight_en>]
    (print, Move to safe height)
    G53 G00 Z#<_tc_safeheight>
    o<sh> endif
    ;o<po> if [#<_tc_pos_en>]
    ;(print, Move to position)
    ;o<sh> if [#<_tc_safeheight_en>]
    ;G53 G00 A#<test_a> Y#<_tc_pos_y>
    ;G53 G00 Z#<_tc_pos_z>
    G53 G00 A#<tool>
    o<sh> endif
    ;o<po> endif
    G09
    o<ac> if [AND[#<_tc_action>, 1]]
    o<tn> if [#<_toolchangename>]
    (msg,Change tool to\ $<toolchangename>)
    o<tn> else
    (msg,Change tool:\ #<_current_tool,0>: $<current_toolname>\to\ #<_selected_tool,0>: $<selected_toolname>)
    o<tn> endif
    o<ac> else
    (print, Change tool to $<toolchangename>)
    o<tn> else
    (print, Change tool #<_current_tool,0> to #<_selected_tool,0>)
    o<tn> endif
    o<ac> endif
    o<ac> if [AND[#<_tc_action>, 2]]
    M0
    o<ac> endif
    G09
    o<atcen> if [#<_tc_atc_en>]
    (print, ATC enabled)
    o<un> if [#<_current_tool> GT 0]
    (print, Unload tool #<_current_tool,0>)
    o<ex> if [#<_tool_exists|#<_current_tool>> EQ 0]
    (msg,Current tool #<_current_tool,0> does not exist in tool table)
    M2
    o<ex> endif
    o<skp> if [#<_tool_skipchange_num|#<_current_tool>> EQ 0]
    #<unposx> = #<_tool_tc_x_num|#<_current_tool>>
    #<unposy> = #<_tool_tc_y_num|#<_current_tool>>
    #<unposz> = #<_tool_tc_z_num|#<_current_tool>>
    #<unposx_in1> = [#<unposx> - #<_tc_unload_in1_x>]
    #<unposy_in1> = [#<unposy> - #<_tc_unload_in1_y>]
    #<unposz_in1> = [#<unposz> - #<_tc_unload_in1_z>]
    #<unposx_in2> = [#<unposx_in1> - #<_tc_unload_in2_x>]
    #<unposy_in2> = [#<unposy_in1> - #<_tc_unload_in2_y>]
    #<unposz_in2> = [#<unposz_in1> - #<_tc_unload_in2_z>]
    (print, Unload in2 position X#<unposx_in2> Y#<unposy_in2> Z#<unposz_in2>)
    (print, Unload in1 position X#<unposx_in1> Y#<unposy_in1> Z#<unposz_in1>)
    (print, Unload position X#<unposx> Y#<unposy> Z#<unposz>)
    o<unpos> if [#<_tc_safeheight_en>]
    G53 G00 X#<unposx_in2> Y#<unposy_in2>
    G53 G00 Z#<unposz_in2>
    o<unpos> else
    G53 G00 X#<unposx_in2> Y#<unposy_in2> Z#<unposz_in2>
    o<unpos> endif
    G53 G01 X#<unposx_in1> Y#<unposy_in1> Z#<unposz_in1> F#<_tc_atc_speed2>
    G53 G01 X#<unposx> Y#<unposy> Z#<unposz> F#<_tc_atc_speed>
    o<unp11> if [[#<_tc_unload_pin1> GT 0] AND [#<_tc_unload_pin1set1> GT 0]]
    M62 P#<_tc_unload_pin1> Q[#<_tc_unload_pin1set1>-1]
    o<unp11> endif
    o<und11> if [#<_tc_unload_pin1delay1> GT 0]
    G04 P#<_tc_unload_pin1delay1>
    o<und11> endif
    o<unp12> if [[#<_tc_unload_pin1> GT 0] AND [#<_tc_unload_pin1set2> GT 0]]
    M62 P#<_tc_unload_pin1> Q[#<_tc_unload_pin1set2>-1]
    o<unp12> endif
    o<und12> if [#<_tc_unload_pin1delay2> GT 0]
    G04 P#<_tc_unload_pin1delay2>
    o<und12> endif
    o<unp21> if [[#<_tc_unload_pin2> GT 0] AND [#<_tc_unload_pin2set1> GT 0]]
    M62 P#<_tc_unload_pin2> Q[#<_tc_unload_pin2set1>-1]
    o<unp21> endif
    o<und21> if [#<_tc_unload_pin2delay1> GT 0]
    G04 P#<_tc_unload_pin2delay1>
    o<und21> endif
    o<unp22> if [[#<_tc_unload_pin2> GT 0] AND [#<_tc_unload_pin2set2> GT 0]]
    M62 P#<_tc_unload_pin2> Q[#<_tc_unload_pin2set2>-1]
    o<unp22> endif
    o<und22> if [#<_tc_unload_pin2delay2> GT 0]
    G04 P#<_tc_unload_pin2delay2>
    o<und22> endif
    #<unposx_out1> = [#<unposx> + #<_tc_unload_out1_x>]
    #<unposy_out1> = [#<unposy> + #<_tc_unload_out1_y>]
    #<unposz_out1> = [#<unposz> + #<_tc_unload_out1_z>]
    #<unposx_out2> = [#<unposx_out1> + #<_tc_unload_out2_x>]
    #<unposy_out2> = [#<unposy_out1> + #<_tc_unload_out2_y>]
    #<unposz_out2> = [#<unposz_out1> + #<_tc_unload_out2_z>]
    (print, Unload out1 position X#<unposx_out1> Y#<unposy_out1> Z#<unposz_out1>)
    (print, Unload out2 position X#<unposx_out2> Y#<unposy_out2> Z#<unposz_out2>)
    G53 G01 X#<unposx_out1> Y#<unposy_out1> Z#<unposz_out1> F#<_tc_atc_speed>
    G53 G01 X#<unposx_out2> Y#<unposy_out2> Z#<unposz_out2> F#<_tc_atc_speed2>
    o<sh> endif
    o<skp> endif
    o<un> endif
    o<ld> if [#<_selected_tool> GT 0]
    (print, Load tool #<_selected_tool,0>)
    o<ex> if [#<_tool_exists|#<_selected_tool>> EQ 0]
    (msg,Selected tool #<_selected_tool,0> does not exist in tool table)
    M2
    o<ex> endif
    o<skp> if [#<_tool_skipchange_num|#<_selected_tool>> EQ 0]
    #<ldposx> = #<_tool_tc_x_num|#<_selected_tool>>
    #<ldposy> = #<_tool_tc_y_num|#<_selected_tool>>
    #<ldposz> = #<_tool_tc_z_num|#<_selected_tool>>
    #<ldposx_in1> = [#<ldposx> - #<_tc_load_in1_x>]
    #<ldposy_in1> = [#<ldposy> - #<_tc_load_in1_y>]
    #<ldposz_in1> = [#<ldposz> - #<_tc_load_in1_z>]
    #<ldposx_in2> = [#<ldposx_in1> - #<_tc_load_in2_x>]
    #<ldposy_in2> = [#<ldposy_in1> - #<_tc_load_in2_y>]
    #<ldposz_in2> = [#<ldposz_in1> - #<_tc_load_in2_z>]
    (print, Load in2 position X#<ldposx_in2> Y#<ldposy_in2> Z#<ldposz_in2>)
    (print, Load in1 position X#<ldposx_in1> Y#<ldposy_in1> Z#<ldposz_in1>)
    (print, Load position X#<ldposx> Y#<ldposy> Z#<ldposz>)
    o<ldpos> if [#<_tc_safeheight_en>]
    G53 G00 X#<ldposx_in2> Y#<ldposy_in2>
    G53 G00 Z#<ldposz_in2>
    o<ldpos> else
    G53 G00 X#<ldposx_in2> Y#<ldposy_in2> Z#<ldposz_in2>
    o<ldpos> endif
    G53 G01 X#<ldposx_in1> Y#<ldposy_in1> Z#<ldposz_in1> F#<_tc_atc_speed2>
    G53 G01 X#<ldposx> Y#<ldposy> Z#<ldposz> F#<_tc_atc_speed>
    o<ldp11> if [[#<_tc_load_pin1> GT 0] AND [#<_tc_load_pin1set1> GT 0]]
    M62 P#<_tc_load_pin1> Q[#<_tc_load_pin1set1>-1]
    o<ldp11> endif
    o<ldd11> if [#<_tc_load_pin1delay1> GT 0]
    G04 P#<_tc_load_pin1delay1>
    o<ldd11> endif
    o<ldp12> if [[#<_tc_load_pin1> GT 0] AND [#<_tc_load_pin1set2> GT 0]]
    M62 P#<_tc_load_pin1> Q[#<_tc_load_pin1set2>-1]
    o<ldp12> endif
    o<ldd12> if [#<_tc_load_pin1delay2> GT 0]
    G04 P#<_tc_load_pin1delay2>
    o<ldd12> endif
    o<ldp21> if [[#<_tc_load_pin2> GT 0] AND [#<_tc_load_pin2set1> GT 0]]
    M62 P#<_tc_load_pin2> Q[#<_tc_load_pin2set1>-1]
    o<ldp21> endif
    o<ldd21> if [#<_tc_load_pin2delay1> GT 0]
    G04 P#<_tc_load_pin2delay1>
    o<ldd21> endif
    o<ldp22> if [[#<_tc_load_pin2> GT 0] AND [#<_tc_load_pin2set2> GT 0]]
    M62 P#<_tc_load_pin2> Q[#<_tc_load_pin2set2>-1]
    o<ldp22> endif
    o<ldd22> if [#<_tc_load_pin2delay2> GT 0]
    G04 P#<_tc_load_pin2delay2>
    o<ldd22> endif
    #<ldposx_out1> = [#<ldposx> + #<_tc_load_out1_x>]
    #<ldposy_out1> = [#<ldposy> + #<_tc_load_out1_y>]
    #<ldposz_out1> = [#<ldposz> + #<_tc_load_out1_z>]
    #<ldposx_out2> = [#<ldposx_out1> + #<_tc_load_out2_x>]
    #<ldposy_out2> = [#<ldposy_out1> + #<_tc_load_out2_y>]
    #<ldposz_out2> = [#<ldposz_out1> + #<_tc_load_out2_z>]
    (print, Unload out1 position X#<ldposx_out1> Y#<ldposy_out1> Z#<ldposz_out1>)
    (print, Unload out2 position X#<ldposx_out2> Y#<ldposy_out2> Z#<ldposz_out2>)
    G53 G01 X#<ldposx_out1> Y#<ldposy_out1> Z#<ldposz_out1> F#<_tc_atc_speed>
    G53 G01 X#<ldposx_out2> Y#<ldposy_out2> Z#<ldposz_out2> F#<_tc_atc_speed2>
    o<sh> endif
    o<skp> endif
    o<ld> endif
    M6
    o<atcen> else
    M6
    o<atcen> endif
    o<tm> if [[#<_tc_toolmeasure> GT 0] AND [#<_tool_skipmeasure_num|#<_current_tool>> EQ 0]]
    G09
    (print, Measure tool)
    #<sox> = [DEF[#<_tool_so_x_num|#<_current_tool>>,0]]
    #<soy> = [DEF[#<_tool_so_y_num|#<_current_tool>>,0]]
    #<soz> = [DEF[#<_tool_so_z_num|#<_current_tool>>,0]]
    G53 G00 Z#<_tooloff_safeheight>
    G53 G00 X[#<_tooloff_sensorx> - #<sox>] Y[#<_tooloff_sensory> - #<soy>]
    G53 G00 Z#<_tooloff_rapidheight>
    M11P0
    G53 G38.2 Z-100000 F#<_tooloff_speed>
    G91 G53 G01 Z[+#<_tooloff_swdist>]
    o<low> if [#<_tooloff_speed_low> GT 0]
    G90 G53 G38.2 Z-100000 F#<_tooloff_speed_low>
    G91 G53 G01 Z[+#<_tooloff_swdist>] F#<_tooloff_speed>
    o<low> endif
    M11P1 G90
    o<chk> if[ACTIVE[] AND NOTEXISTS[#<_probe_z>]]
    (msg,Measuring failed)
    M2
    o<chk> endif
    #<off> = [#<_probe_z> - #<_tooloff_sensorz> - #<soz>]
    o<tmset> if [#<_tc_toolmeasure> EQ 2]
    (print, Set tooltable Z#<off>)
    G10 L1 P#<_current_tool> Z#<off>
    #<toisset>=2
    o<tmset> elseif [#<_tc_toolmeasure> EQ 1]
    (print, Set tool offset Z#<off>)
    G43.1 Z#<off>
    #<toisset>=1
    o<tmset> endif
    o<tm> endif
    o<toen> if [#<_tc_tooloff_en>]
    M72
    M71
    (print, Enable tool offset)
    o<tois> if [#<_tc_tooloff_en> EQ 2]
    G43
    o<tois> elseif [#<_tc_tooloff_en> EQ 1]
    G43.1
    o<tois> endif
    o<toen> endif
    o<ar> if [#<_tc_autoreturn>]
    (print,AutoReturn)
    o<chk> if [#<_z> LT #<wstartz>]
    G00 Z#<wstartz>
    o<chk> endif
    G00 X#<wstartx> Y#<wstarty>
    G00 Z#<wstartz>
    o<ar> endif
    o<sp> if [#<_tc_spindlecheck> AND [#<spindle> EQ 3]]
    (print, Turn spindle CW)
    M3
    o<sp> elseif [#<_tc_spindlecheck> AND [#<spindle> EQ 4]]
    (print, Turn spindle CCW)
    M4
    o<sp> endif
    Mar 2024
    30
    Quote Originally Posted by impi62 View Post
    Which controller you using ??? explain me everything at [email protected]
    Mar 2017
    1325
    You can use custom parameter from your tool table to store A value for each tool.
    https://cnc.zone/tng/parameters/param-_tool_par1_num
    https://cnc.zone/tng/machine_menu/ma...l_table-custom
    Dec 2006
    16
    _tool_par1_num, _tool_par2_num, _tool_par3_num
    Must i put this parameters.txt?
    I already set tool 1 to par1
    Dec 2006
    16
    These are changes to script - see below in purple
    Must i add _tool_par1_num to the parameter.txt file? and what is num??
    M6
    M99
    o<chk> endif
    M6
    M99
    o<chk> endif
    M2
    o<PlanetCNC> endif
    M73
    M50P0
    M55P0
    M56P0
    M57P0
    M10P1
    M11P1
    (print,Toolchange)
    #<toisset>=0
    #<wstarta> = #<_a>
    #<wstarty> = #<_y>
    #<wstartz> = #<_z>
    M5
    o<sp> endif
    M99
    o<st> endif
    o<sh> endif
    G53 G00 A#<_tc_pos_a> Y#<_tc_pos_y>
    o<sh> else
    G53 G00 A#<_tc_pos_a> Y#<_tc_pos_y> Z#<_tc_pos_z>
    o<sh> endif
    o<po> endif
    G09
    o<tn> else
    o<tn> endif
    o<ac> else
    o<tn> else
    o<tn> endif
    o<ac> endif
    M0
    o<ac> endif
    G09
    M2
    o<ex> endif
    o<unpos> else
    o<unpos> endif
    o<unp11> endif
    o<und11> endif
    o<unp12> endif
    o<und12> endif
    o<unp21> endif
    o<und21> endif
    o<unp22> endif
    o<und22> endif
    o<sh> endif
    o<skp> endif
    o<un> endif
    M2
    o<ex> endif
    o<ldpos> else
    o<ldpos> endif
    o<ldp11> endif
    o<ldd11> endif
    o<ldp12> endif
    o<ldd12> endif
    o<ldp21> endif
    o<ldd21> endif
    o<ldp22> endif
    o<ldd22> endif
    o<sh> endif
    o<skp> endif
    o<ld> endif
    M6
    o<atcen> else
    M6
    o<atcen> endif
    G09
    M11P0
    o<low> endif
    M11P1 G90
    M2
    o<chk> endif
    #<toisset>=2
    G43.1 Z#<off>
    #<toisset>=1
    o<tmset> endif
    o<tm> endif
    M72
    M71
    G43
    G43.1
    o<tois> endif
    o<toen> endif
    (print,AutoReturn)
    G00 Z#<wstartz>
    o<chk> endif
    G00 Z#<wstartz>
    o<ar> endif
    M3
    M4
    o<sp> endif
    Dec 2006
    16
    Please can you give some kind of actual example. I'm struggling with this for weeks now
    Dec 2006
    16
    This is my M6 script now
    M6
    M99
    o<chk> endif
    M6
    M99
    o<chk> endif
    M2
    o<PlanetCNC> endif
    M73
    M50P0
    M55P0
    M56P0
    M57P0
    M10P1
    M11P1
    (print,Toolchange)
    #<toisset>=0
    #<wstarta> = #<_a>
    #<wstarty> = #<_y>
    #<wstartz> = #<_z>
    M5
    o<sp> endif
    M99
    o<st> endif
    o<sh> endif
    G53 G00 A#<_tool_par1_num> Y#<_tc_pos_y>
    o<sh> else
    G53 G00 A#<_tool_par1_num> Y#<_tc_pos_y> Z#<_tc_pos_z>
    o<sh> endif
    o<po> endif
    G09
    o<tn> else
    o<tn> endif
    o<ac> else
    o<tn> else
    o<tn> endif
    o<ac> endif
    M0
    o<ac> endif
    G09
    M2
    o<ex> endif
    o<unpos> else
    o<unpos> endif
    o<unp11> endif
    o<und11> endif
    o<unp12> endif
    o<und12> endif
    o<unp21> endif
    o<und21> endif
    o<unp22> endif
    o<und22> endif
    o<sh> endif
    o<skp> endif
    o<un> endif
    M2
    o<ex> endif
    o<ldpos> else
    o<ldpos> endif
    o<ldp11> endif
    o<ldd11> endif
    o<ldp12> endif
    o<ldd12> endif
    o<ldp21> endif
    o<ldd21> endif
    o<ldp22> endif
    o<ldd22> endif
    o<sh> endif
    o<skp> endif
    o<ld> endif
    M6
    o<atcen> else
    M6
    o<atcen> endif
    G09
    M11P0
    o<low> endif
    M11P1 G90
    M2
    o<chk> endif
    #<toisset>=2
    G43.1 Z#<off>
    #<toisset>=1
    o<tmset> endif
    o<tm> endif
    M72
    M71
    G43
    G43.1
    o<tois> endif
    o<toen> endif
    (print,AutoReturn)
    G00 Z#<wstartz>
    o<chk> endif
    G00 Z#<wstartz>
    o<ar> endif
    M3
    M4
    o<sp> endif
    Dec 2006
    16
    Dec 2006
    16
    OK managed to get it working. All tool changes working as it should. Thank you for the pointers
    Now another issue. Not affecting the actual operation of the tool change but would make it faster. Does planet cnc have a "rollover"?
    Meaning, can a rotary axis be set from 0 degrees to 360 degrees and instead of going to 361 degrees it "rolls over" to o again.
    So that during a tool change, if tool is unloaded at 350 degrees and next tool is at 10 degrees, the axis just moves 20 degrees to the shortest distance to next tool instead of reversing 340 degrees to get back to.position 10 degree. Hope I'm making sense here.
    Can anyone shed some light?
    Mar 2017
    1325
    Take a look, how in Unwind implemented.
    https://cnc.zone/tng/machine_menu/ma...osition_unwind
    Aug 2020
    133
    this only helps you if you are already at a position lager than 360°
    not if you want to go from, say, 350 to 10. In this case you would need to go to 370 and then call the unwind (btw is there a gcode to call unwind)
    Mar 2017
    1325
    Unwind is this g-code:
    G10 L9 A[#<_machine_a> MOD 360]
  1. Replies: 1
    Last Post: 03-07-2021, 11:42 PM
  2. Where i can find script for atc?
    By syntronik in forum Milling
    Last Post: 03-31-2020, 04:46 PM
  3. ATC Automatic Tool Changer Mach3 Script Screenset
    By DeanR181 in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-26-2019, 07:25 AM
  4. Planet CNC
    By yar20 in forum PlanetCNC
    Last Post: 04-26-2018, 05:31 PM
  5. Replies: 1
    Last Post: 01-03-2018, 10:13 AM
