586,444 active members*
3,297 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Is there a parameter setting to lower the threashold for Low Voltage?
Results 1 to 3 of 3
    May 2013
    170
    I'm running with 2 seperate phase perfect phase converters.
    I have my scroll air compressor hooked up to one along with with a Haas super mini mill ( no issues )
    On the other phase converter I have a DM-2 ( no issues )
    In the past I tried to have my DM-2 on the unit that had the air compressor, but every time the air compressor would turn on it would alarm low voltage
    So I moved it to the other unit and everything was fine.
    But recently I sold my mini mill and replaced it with a DM-1 and now the issue has popped up again.... ( when the compressor turns on my DM-1 alarms low voltage and turns off ( This happens even when the mill is just sitting idle )
    My output voltage from the phase converter is 242v
    When the compressor turns on the output voltage drops to 238v
    I have my wiring on the Haas going to the taps that have a range from ( 227 to 243 v )
    So I'm wondering if there is a setting on the machine that I can loosen up the voltage parameters that would trigger the alarm?
    The DM-1 is a 2018 with NG controller
    Thank You...
    Kent
    May 2013
    170
    Re: Is there a parameter setting to lower the threashold for Low Voltage?
    Just an update on this.... I talked to my local Haas dealer and they said that when you check the voltage on TB2 Output ( this is the terminals just to the left of the incoming Taps ) that there is a 10% range in voltage variation, so I checked that when the compressor turned on and it looks like it's just pushing it for a split second outside that limit.
    So I'm looking at a couple of options..
    Option 1 is to put this machine on the same phase converter that the DM2 is on, and that would leave just the air compressor on the second phase converter.
    Option 2 is to look at adding a soft start onto the compressor.
    I don't have any experiance with soft starters, so I'm not sure if that's even an option on my compressor. ( Eastwood QST-80/120 )
    So if anyone has any advice on soft starters please share...
    Thanks,
    Kent
    May 2013
    170
    I ended up moving the CNC over to my second phase converter so now the air compressor is on the phase converter by itself and that did the trick....
  1. Changing Low Coolant message to lower %
    By JNickalou in forum Haas Mills
    Last Post: 06-01-2023, 08:12 PM
  2. 40w laser tube lower voltage connector burn mark
    By NaN in forum Laser Hardware
    Last Post: 05-13-2020, 12:17 PM
  3. Low Voltage vs High Voltage Stepper motors?
    By Brian_M in forum Stepper Motors / Drives
    Last Post: 06-21-2017, 07:29 PM
  4. High voltage power supply, low voltage perihperals
    By feechl in forum CNC Machine Related Electronics
    Last Post: 01-07-2014, 02:12 AM
