586,993 active members*
3,002 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > Torchmate 501A Signal generator lost conection when plasma is ON
Results 1 to 2 of 2
    Mar 2013
    1
    I have a Torchmate 4x4 Series Table with a Hyperterh Plamsa Cutter, working for several years, wherever since a few day ago start whir this issue:
    Once I Turn on the Signal generator and the AVHC, everthing is fine the move and the run program but when start to cut, and light the plasma torch appers the error "Torchmate cannot connect again the signal generator, error code 18003, or "Tochmate timed out while attempting to send data to the Signal Generator, The Sofware is no longer connected to the Signal generator.
    I already check all the conections, but the provlem persist, any comentes about it?
    Software: Version 4.0.59
    Signal Generator: 501A
    Type Connection: USB
    Mar 2014
    5
    A mysterious stranger awaits you without obligations
    Discover the ultimate in relaxed romance with the best casual dating platform! Discover new possibilities, forbidden desires Actual Women Super casual Dating
  1. 501a signal generator question/problem
    By Jeonlyep in forum Torchmate
    Last Post: 02-19-2024, 01:29 AM
  2. ISO 401a or 501a Signal Generator
    By quickjam in forum Torchmate
    Last Post: 01-01-2021, 06:57 AM
  3. Want to buy: FlashCut or Torchmate seral signal generator (or fix mine)
    By JackMcCornack in forum Want To Buy...Need help!
    Last Post: 04-17-2013, 02:06 AM
  4. Flashcut/torchmate Signal Generator + ShopBot?
    By metalhead781 in forum FlashCut CNC
    Last Post: 02-03-2012, 09:33 PM
  5. SIGNAL GENERATOR 501A
    By ecamacho in forum Torchmate
    Last Post: 01-18-2008, 10:57 PM
