586,655 active members*
3,245 visitors online*
Hybrid View
    Jan 2024
    Unhappy dmu 70 evolution deckel maho
    welcome everybody
    I own a 5 axis machine dmu 70 evolution deckel maho
    I have a problem. There was a fire in the machine and the entire control was damaged. I bought a used control unit and upon working, I found it working for only 3 tries. When I activated the fourth and fifth X, a problem appeared. I found that the additional axes were not activated on the Sik chip.
    I wrote to the company and it said it had stopped supporting the itnc530
    Is there a solution to this problem, whether activation, crack, or software that solves the problem?
    Re: dmu 70 evolution deckel maho
    Quote Originally Posted by elprinc View Post
    welcome everybody
    Maybe the used control unit you bought is only 3 axes version.
    The prices of 5 axes and 3 axes are different, if the hardwares are the same, then can be upgraded by parameter setting, but need to ask the controller manufacturer.
  1. dmu 70 evolution deckel maho postprocess
    By elprinc in forum Postprocessor for CAM
    Last Post: 04-14-2024, 01:47 AM
  2. Deckel Maho DMU 50 eVolution - Heidenhain Millplus
    By sandeepmb123 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-26-2021, 07:58 PM
  3. Deckel Maho DMU 50 VL
    By waltteris in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-13-2016, 09:32 PM
  4. Deckel Maho DMU 70 Evolution; Blum laser trouble
    By donuts in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 02-25-2010, 07:38 PM
