586,961 active members*
2,726 visitors online*
Results 1 to 20 of 21
    Apr 2004
    5742
    Re: Resurrecting old hobby CNC from the 90s
    If the old computer still works, you should be able to run it with Mach3, which has a parallel port driver. If you're getting rid of the old controller, I'd suggest getting a Geckorive G-540; the 25-pin cable will go straight into it from the computer.
    Andrew Werby
    Website
    Apr 2024
    10
    Quote Originally Posted by awerby View Post
    I'm trying to get it to work. First off was getting the keyboard repaired as some keys were stuck down. Having fixed that I am now getting an "I/O conflict 378" which I don't understand. I've tried with the controller disconnected and plugged into the parallel port both turned on and off which made no difference.
    Apr 2024
    10
    I'm working on getting the old PC up and running, so far stuck with I/O conflict 378.
    Aug 2009
    1573
    Quote Originally Posted by Spope View Post
    ... IF, the bios has been reset I bet you have to change one or more of interrupts to factory settings to fix the conflict...Want ever they were or should be.
    DJ
  1. Help resurrecting a new to me CNC setup
    By akcarl in forum Controller & Computer Solutions
    Last Post: 05-19-2021, 05:20 AM
  2. Help resurrecting a new to me CNC setup
    By akcarl in forum CNC Machine Related Electronics
    Last Post: 05-15-2021, 08:47 AM
  3. CNC SERVICE MANAGER to 90s NC
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 11-02-2013, 12:16 AM
  4. CNC SERVICE MANAGER to 90s NC
    Last Post: 10-06-2013, 03:56 AM
  5. CNC SERVICE MANAGER to 90s NC
    Last Post: 09-29-2013, 10:43 PM
