586,850 active members*
2,078 visitors online*
Results 1 to 2 of 2
    May 2009
    1333
    DIN Rail Terminal Separators
    I don’t have the separators for the DIN Terminals type I’m using. I will have 4 groups of terminals, 120VAC, 48VDC, 24VDC and 12VDC and each group will be spaced apart. Is it ok to use electrical tape between the terminals, perhaps something else?
    Nicolas
    Nicolas
    Apr 2024
    1
    Re: DIN Rail Terminal Separators
    Quote Originally Posted by kolias View Post
    minecraftle game
    Nicolas
    Hello, I think you should use dedicated DIN rail terminal separators. These separators are specifically designed for this purpose and provide reliable insulation and separation between adjacent terminals. They are typically made of insulating materials that meet safety standards and ensure proper electrical isolation.
  1. Started a new series on DIN Rail
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 10-01-2017, 05:00 PM
  2. Would like to add in Din Terminal blocks, what should route through them?
    By davy182 in forum CNC Machine Related Electronics
    Last Post: 10-26-2014, 09:04 PM
  3. DIN Terminal Wiring
    By kolias in forum Open Source CNC Machine Designs
    Last Post: 08-21-2013, 02:57 AM
  4. DIN 3 Rail & Wire Duct Screw Sizes??
    By jevs in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2011, 03:35 AM
  5. replacement DIN rail parts
    By teknein in forum CNC Machine Related Electronics
    Last Post: 02-23-2008, 04:16 PM
