586,744 active members*
5,652 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Machining Centres > 1998 Hartford VMC-850 Meldas 520 Control
Results 1 to 1 of 1
    Oct 2011
    5
    on the meldas control how does the servo over ride work.. i have an axis hard on the limit switch and i cant seem to move the y axis away from it..
    Re: 1998 Hartford VMC-850 Meldas 520 Control
    Press and hold the overtravel release button without releasing it.
    At the same time, in the handwheel mode, select the Y-axis and move the Y-axis back in the opposite direction to the overtravel,
    until the Y axis get away from the limit switch.
    Then press the reset button to clear the alarm.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
