586,920 active members*
2,685 visitors online*
Results 1 to 7 of 7
    Jan 2019
    59
    Delta 20 control keeps cutting out
    Hi all,
    My Delta 20 control has started doing something new, which is causing me problems
    It powers on ok, and I can run programs etc. however, it is now quite frequently cutting out and requiring a power cycle to reset.
    When it happens, the display goes blank and the servos shut off. The fans in the control box keep running, but the machine is unresponsive to any button pushes. About 1 time in 5, when I cycle the power switch I get a "power fail" message when the control reboots, and all program /offset data is missing and has to be reloaded.
    On this machine, I was previously dealing with the power fail (and loss of programs) issue on startup, which i had traced back to a loose connection on the white PF lead on the power supply. That issue seemed to go away when I tightened that connection, but now I'm having this issue while running the machine.
    I looked in the control cabinet, and there are a couple of red LEDs lit up when it happens. I tried to take pictures of the LEDS, as I'm not sure which boards are which in the control and not sure how to describe them.
    Hoping someone else has run into this issue and can help advise.
    I'm thinking its most likely a sign of power supply failure, and have ordered a meanwell QP-320F PSU to see if replacing will solve the issue. If anyone can help advise on the replacement procedure as well, that would also be greatly appreciated!
    Lee
    Attached Thumbnails Attached Thumbnails 20240409_214028.jpg   20240409_214113.jpg   20240409_214104.jpg
    Aug 2009
    1573
    Re: Delta 20 control keeps cutting out
    Hi leeko,
    ...Yes. I would agree the PS would be the 1st to check or time to replace.
    Good luck,
    DJ
    Jan 2019
    59
    Quote Originally Posted by machinehop5 View Post
    Hi leeko,
    Good luck,
    DJ
    I replaced the power supply on my delta 20 with a meanwell qp-320f, and got everything installed last night. Unfortunately, my symptoms are the same with the new power supply - the control runs fine, but periodically stops responding with a blank screen and the servos shut down. The red WDT FAIL led on the PIC board, and the red PROC WDT FAIL led on the AUX board are lit when this happens.
    I'm not seeing any ripple on the new PSU Voltages, at least with my non TRMS meter. They're reading as 25.0v, 5.11v, +15.1v, -15.1v.
    I had previously pulled all the boards and cleaned the contacts, as well as inspecting the capacitors and crystal oscillators, and everything looked ok. I plan to redo all of that later today.
    Can anyone suggest anything else to look for before calling parts and smarts?
    Aug 2009
    1573
    ...check all cool Fans.....could try removing and reinstalling all the IC Chips on all the boards. Look around or feel for anything getting extra hot.
    Jan 2019
    59
    Huh, it's interesting you say that - I left the control cabinet open, and it's been on/idle for 5 hours now without freezing. It doesn't feel particularly hot in the cabinet, and all the fans seem to be running ok, but maybe... Going to leave it running until it freezes again, then I'll start pulling components etc
    Jan 2019
    59
    Nope, still freezing despite having the cabinet open. Tonight, it did it within about 20 minutes of switching it on.
    I read a forum post tonight that mentioned having an e-stop condition when the auto way oiler is empty. Is that a possibility here? My mill has a bijur oiler on the back, with a solenoid attached. I think it might be empty, but won't be able to check till tomorrow.
    Jan 2019
    59
    The control does seem to be overheating - if I run the machine with the control box open and a fan blowing into the cabinet, I was able to leave it running for ~36 hours without a problem. After I removed the fan and closed the box, it hung within 45 minutes
    The airflow within the box is pretty poor. There are 3 100mm fans inside, but there's no way for cool air to get in or out. I may need to think about cutting a hole in the cabinet to add another fan or 2
    For those of you with a working Delta 20, can someone let me know what direction the fan on the top of the control card cage blows? Mine is currently blowing up (drawing air from the bottom of the cabinet up through the components) but I'm thinking it should maybe blow down instead
  1. X servo error - delta 20 control
    By leeko in forum Dynapath
    Last Post: 11-23-2022, 05:39 AM
  2. Dynapath Delta Autocon control
    By ZAWEK in forum Milling
    Last Post: 08-02-2019, 08:37 PM
  3. Delta 3 phase and Fanuc control
    By scadvice in forum Fanuc
    Last Post: 01-13-2009, 09:15 PM
  4. Dynapath Delta 20 control
    By Steve A. in forum DNC Problems and Solutions
    Last Post: 08-17-2006, 07:56 PM
