586,523 active members*
3,386 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Servo Control for Haas Barfeeder
Results 1 to 1 of 1
    Jul 2009
    28
    I'm getting a Error on the Servo Control for a bar feeder. It says "Ser Err" does that mean Servo Error or Serial Error. Also any ideas what to check first.
    Re: Servo Control for Haas Barfeeder
    Ser-Err (Servo Error) during first home find initiation.
    Ser-Err (Servo Error) upon indexing.
    Possible causes:
    1- Faulty main cable or cable connector.
    2- Table driving a heavy load.
    3- Table is jammed.
    4- Check Parameter 25.
    5- Head is iammed
    Solution:
    1- Check cable and motor fuse.
    2- Reduce workload weight and/or feed rates.
    3- Eliminate obstruction.
    4- Must be set to 8 for HRT 160, 210, 450 (19 for HRT 310)
    5- Eliminate obstruction
    Jul 2009
    28
    Attachment 504004
    Here is a picture of the Servo Driver
