Quote Originally Posted by arturod View Post
That fault signal is common with the mains of the motor. You cannot hook it up directly to inputs on the masso as it will create a ground loop. Please check these boards that will help you wire this:
https://cnc4pc.com/c86-connector-for...ontroller.html
https://cnc4pc.com/c34-connector-g320-drivers.html
Arturo Duncan
https://cnc4pc.com
Wow, wish I had known about these months ago! Thanks heaps for the info. I'm currently using the masso differential receiver module, do these boards provide the same function?
I've got pin 5 hooked up to the inputs, what kind of problems would I be seeing with a ground loop? Iv'e had a few of the drives fault out and even the controller restart for no apparent reason. Thought it could be power fluctuations but also sounds like it could be ground loop issues.
