587,003 active members*
3,036 visitors online*
Results 1 to 5 of 5
    Dec 2009
    33
    Mazak v515/40
    I’ve been thinking about getting rid of my 1995 Mazak mill and upgrading to something newer because of the control being so limited from its age as it has very little memory for complex tool paths and would be extremely expensive to add a rotary which I’m really needing more and more it seems. That being said, machine is paid for and still makes good parts so I’ve been considering retrofitting the controls with something modern and Linux cnc as well as a few others keeps coming to mind.
    I have done a centroid retrofit on a hurco knee style mill and learned a lot but I have read Linux cnc would be much more involved. Centroid worked great but was really lacking on the user interface. I see many UI’s have been being developed that run on top of Linux cnc that look really good.
    I would like to keep my original 3.5kw Mitsubishi servos and drives which are analog input as they still work great and would be pricy to replace. I see mesa has the 7i77 card for analog output but what I’m not sure about is which motion control card to use. I see multiple variants that work with the 7i77.
    What kind of performance can one expect retrofitting with a Linux mesa combination? Plenty of look ahead for high speed tool paths?
    Attached some pics of my machine.
    IMG-3626
    IMG-3673
    IMG-3631
    IMG-3627
    Re: Mazak v515/40
    Better use NC based than PC based CNC controller.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Dec 2005
    600
    Re: Mazak v515/40
    Quote Originally Posted by cncmakers001 View Post
    Nonsense. LinuxCNC is used in many industrial applications. It's what it was designed for.
    Mark
    Mar 2015
    47
    Re: Mazak v515/40
    Greetings,
    Join the LinuxCNC Forum and search for similar conversions.
    LinuxCNC
    The support from users is rather good.
    Cheers,
    David
    Dec 2009
    33
    Quote Originally Posted by fc60 View Post
    Greetings,
    LinuxCNC
    Cheers,
    David
    Thanks I will do!
  1. Please help me about Mazak FJV-250-Mazak Fushion 640M cnc milling machine
    By DUCVUONG in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-16-2021, 02:03 AM
  2. Mazak V515/40 Alarm 268
    By JPetrik in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-13-2017, 07:53 PM
  3. Mazak V515 memory upgrade
    By beniok in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-23-2014, 01:11 PM
  4. Need help with a fault on my mazak miller v515
    By dannyf2286 in forum Community Club House
    Last Post: 01-08-2014, 11:02 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
