586,545 active members*
3,138 visitors online*
    Mar 2024
    8
    NC68 Ezmotion PLC Onboard editing
    Hi friends,
    To access the ladder diagram, I need to change the bit values in register #6451. But even though I made an entry, I cannot change the value. Is there a procedure such as an emergency stop? I couldn't try it because the button was defective. When I press the F0 key, a blank screen appears. #6451 bit value is '00010100', should there actually be access to the ladder menu at this value?
    Mar 2024
    8
    Re: NC68 Ezmotion PLC Onboard editing
    By turning the plc maintenance switch to 1 position, the plc stopped and my problem was solved.
  1. Ezmotion E68 Back-Up
    By Mustafa01980 in forum Mitsubishi controls
    Last Post: 03-26-2024, 10:06 AM
  2. RS232 DB-9 Wiring diagram for EZmotion-NC E60
    By mohanad1820 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-03-2014, 05:16 PM
  3. MITSUBISH OPERATION MANUAL EZMotion-NC E60 needed
    By mohanad1820 in forum Machinery Manuals / Brochures
    Last Post: 01-07-2014, 09:48 AM
  4. Anyone have a copy of "PLC ONBOARD INSTRUCTION MANUAL"
    By Harri J in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-20-2013, 07:56 AM
  5. Mastercam A.E. Onboard
    By mikedebutts in forum Community Club House
    Last Post: 07-11-2010, 07:17 PM
