586,818 active members*
6,480 visitors online*
Results 1 to 1 of 1
    Apr 2024
    Exclamation SInumerik 840D unable to post process for Breton Matrix 800 Machine
    Hi all, We have a 25year old Breton Matrix 800 for which we have only used the 3 axis operations and the default post processor in Autodesk Fusion worked well with no issues, we now want to try 4th and 5th axis operatons as well and I am getting errors when I try to run the code on the CNC.
    Error 1: 'channel 1 block invalid base frame definition for tool carrier offset', The full explanation was in HELMAN CNC which says 'If a tool carrier selection causes a change in the table offset, a valid base frame must be defined in order to store this offset; for more information see machine data 20184 (TOCARR_BASE_FRAME_NUMBER).'
    Error 2: The code on CNC stops executing at N22 CYCLE 800(), I can share the test operation code if required.
    What I tried?
    1. I check for the machine data 20184 on the CNC after executing the program and the parameters look fine.
    2. Create a new machine configuration and manually update the A and C axis with the limits by modifying the default post processor.
    I am not fully understanding the error code and whether the issue is with CNC/Fusion post processing. Any suggestions is greately appreciated.
