586,884 active members*
3,905 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Dump tool offset with reset Fanuc oi-tc
Results 1 to 7 of 7
    Sep 2005
    276
    Hello, I'm trying to find the parameter so when I hit reset it will change the tool number on program check screen, like T0202 hit reset and now it shows T0200 you know dumps the offset. it is dumping the offset but just not showing it on the screen. I want to be able to look at the screen and see if the tool offset is instated or not. I can't find it in the parameter manual, I know I've seen it on other fanuc controls in the past. any help would be great. Thanks
    Dec 2012
    395
    Re: Dump tool offset with reset Fanuc oi-tc
    Check one of the settings for parameter 5002 - 5003
    Sep 2005
    276
    Will do, let you know
    Sep 2005
    276
    No Dice, I think it would be in the Edit/CRT part of the Parameter Book but I can't find it. Thanks for the Reply
    Dec 2009
    966
    Try with the parameter 5003 bit 6 LVC or bit 7 TGC
    LVC Offset value of tool offset
    0 : Not cleared, but held by reset
    1 : Cleared by reset
    TGC Tool geometry compensation value
    0 : Not canceled by reset
    1 : Canceled by reset
    (Valid when bit 6 (LVC) of parameter No.5003, is "1")
    #7 #6 #5 #4 #3 #2 #1 #0
    Sep 2005
    276
    Thanks for the reply Zavateandu, yeah they were both set to one, I don't know? I will keep digging, thanks again
    Sep 2005
    276
    Well I Got it , 1201.7=0 ,3402.6=1 , 3409.7=0 , 5003.6=1 ,5003.7=1 Thanks everyone!
  1. Replies: 9
    Last Post: 04-03-2024, 09:33 PM
  2. Replies: 4
    Last Post: 05-24-2022, 02:49 PM
  3. TOOL OFFSET CANCELS BY RESET FANUC OTF (fapt)
    By sputnikprec in forum Fanuc
    Last Post: 02-06-2015, 12:06 PM
  4. Tool offset reset Fanuc 21i-TB
    By botha.y in forum Fanuc
    Last Post: 03-08-2014, 04:53 AM
  5. Cinci Acramatic 850SX Tool Offset reset!
    By burnthills in forum Cincinnati CNC
    Last Post: 02-25-2010, 07:44 PM
