586,847 active members*
2,290 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 500 A2100 coolant pump
Results 1 to 7 of 7
    May 2023
    8
    Cincinnati arrow 500
    Does anyone know if there’s a fuse or relay and where for the coolant pump on this machine ? Does not want to turn on with the mcode but I can turn it on manually from the contractor
    it was running before.. It ran dry for a little bit so I shut it off and after I filled up and tried turning it on it didn’t want to work after.. I confirmed the pump still works when turned on manually from the contactor
    Pics https://imgur.com/a/ADcIIal
    Mar 2008
    285
    Re: Arrow 500 A2100 coolant pump
    Please provide:
    Machine Serial Number: 70xx-Y0x-xxxx
    Model Type (USA machines): i.e. Exx, ERO, ERD, EKK etc... or Year of Manufacture from separate Plate below Serial Plate (for Europe and rest of the world machines)
    Control Diagram Number: 9120xxxxAyy
    Model Type (USA machines): or Year of Manufacture:
    May 2023
    8
    hi i provided the info with the pictures i put up but here they are
    Machine Serial Number: 7042-A00-KK2092
    Model Type: ERM
    Control Diagram Number: 91203813B
    Mar 2008
    285
    File attached: 91203813B-STD-Coolant-Excerpts.bmp
    If you need more help; Bill Oehler (Fives Hebron Tech Support) can sell you prints or give you part numbers for the Solid State Output Chip.
    1-859-534-4750 USA
    May 2023
    8
    Does he have an extension i can reach him at? been trying to call but no answer
    Mar 2008
    285
    That should be the operator; I just saw Bill last week and he was still working.
    1-859-534-4750 USA
    Mar 2011
    464
    Depending on which machine you have, outputs were typically protected by fuse or opto isolator. I believe yours is the latter but your prints will indicate what you have and where to look.
    If you don't have prints for your machine, contact Fives-Cincinnati and buy a set. You will need to provide serial number and schematic numbers (on s/n plate in your picture).
  1. Arrow 500 A2100 alarm 42-37
    By lchmura in forum Cincinnati CNC
    Last Post: 09-08-2019, 12:32 PM
  2. Spindle Issues Arrow 500 A2100
    By JLaw in forum Cincinnati CNC
    Last Post: 01-10-2013, 09:39 PM
  3. Arrow 500 A2100 various failures
    Last Post: 01-25-2012, 10:06 AM
  4. Arrow 500 with A2100 cnc
    By rai in forum Cincinnati CNC
    Last Post: 07-26-2011, 11:54 PM
  5. A2100 Arrow 500 Error help
    By kentsui in forum Cincinnati CNC
    Last Post: 10-31-2010, 06:44 PM
