586,119 active members*
3,477 visitors online*
    Dec 2006
    112
    Fanuc O-Mate M dripfeed
    Hello!
    I´m trying to get this controller to drip feed and by reading some threads here on cnczone I have found that G127.5 should be on and I found in the ladder that D400.0 set G127.5 and I then changed D400.0 to 1 and then its active in the ladder.
    I can also send programs to the controller so that comunication is working at least.
    I have tried al sorts of thing to make it receive the drip feed, for example setting it in tape mode and pressing start but nothing happends.
    Is there an other procedure?
    And is it the same comunication setting when drip feeding as then receiving a hole program?
    I added some pictures of the controller so you can see what buttons and knobs that are available.
    This is an old wood working machine I´m trying to use for milling and drilling large aluminium plates.
    Dec 2006
    112
    Re: Fanuc O-Mate M dripfeed
    Actually it works now hehe, I noticed now when I downloaded a program and try to run it it waited for comunication so I just started the serial transfer again and then it works
    Using serial to cnc in Fusion 360 by the way, very smooth
  1. Fanuc 0M number and dripfeed?
    By jeppes in forum Fanuc
    Last Post: 07-12-2023, 05:15 AM
  2. Fanuc Omc dripfeed anomaly
    By ThinkLab in forum Fanuc
    Last Post: 11-15-2018, 12:45 PM
  3. Fanuc 3MA dripfeed
    By Namnp2007 in forum Fanuc
    Last Post: 10-30-2012, 10:38 PM
  4. Fanuc 11m Dripfeed
    By vtmv80 in forum Fanuc
    Last Post: 12-30-2009, 05:25 AM
  5. Fanuc 10m dripfeed (DNC)
    By mroy0404 in forum Fanuc
    Last Post: 10-10-2005, 12:27 AM
