586,823 active members*
3,289 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Build a Desktop 5-axis CNC Machine and It Worked!!!
    Mar 2024
    The machine is clearly a desktop cnc. Most of the parts are self-designed including the spindle, motor (servo motor and direct drive motor), ATC, controllers, software and even the chips inside.
    It can cut 10*10*10cm workpiece and handle softmetal and plastics very well.
    Spindle: 12000rpm
    Travel:X160mm/Y210mm/Z130mm
    Would love to have some input from you guys.
    Re: Build a Desktop 5-axis CNC Machine and It Worked!!!
    Nice looking? What control software are you using?
    Jan 2010
    294
    Pics or it didn't happen
    www.steelplinkers.com
    Apr 2018
    134
    I'm closing this thread.
    There are times when claims made on the net are somewhat exaggerated, and perhaps those might be tolerated here. But clearly false info posted by a commercial entity posing as "look what I built" is not going to be acceptable here.
