586,536 active members*
2,828 visitors online*
    May 2008
    78
    C76 settings for Probe 2 in UCCNC
    I have one of those inexpensive touch down probes as shown in the first image below. I have it wired to Port 2, Pin 15 on my C76 board. The probe base is wired to Pin 15 and the probe alligator clip is wired to COM. I get no response to the indicator light on the DIAGNOSTICS screen when I touch the alligator clip to the probe base.
    On the C76 on Port 2 I have the two jumpers set to COM=5V as shown below. I don't believe I touched these during setup a few years ago as I have nothing else coming into the Port 2 inputs.
    I suspect these jumper settings are the issue. Could someone confirm before I go experimenting?
    BH
    Attachment 503254
    Re: C76 settings for Probe 2 in UCCNC
    The probe is just a switch.
    Maybe this info is useful: https://cnc4pc.com/blog/post/wiring-...tches-on-a-c76
    Arturo Duncan
    https://cnc4pc.com
    May 2008
    78
    Got side tracked from the project. Back on it now.
    Thanks for the links Arturo. That should help.
    BH
  1. Adding reverse using UCCNC and CNC4PC C76 card
    By bhdavis1cnc in forum UCCNC Control Software
    Last Post: 01-21-2024, 12:48 AM
  2. Replies: 0
    Last Post: 01-19-2024, 09:30 PM
  3. Basic setup for UCCNC with CNC4PC C76 300ETH
    Last Post: 04-06-2021, 09:56 PM
  4. Help with UC300ETH-C76 and UCCNC?
    By mchesney1 in forum UCCNC Control Software
    Last Post: 10-04-2020, 10:27 PM
  5. Connection issues: c76-us300eth with uccnc
    By gr-cnc in forum UCCNC Control Software
    Last Post: 12-16-2019, 03:55 PM
