586,449 active members*
3,394 visitors online*
    Question Help Please - messed around and my setting are messed up
    Hello
    This site is so helpful I decided to see if anyone could help me again.
    My laser is as follows
    SIHAO
    Shanghai Sihao Machinery Equipment Co, LTD
    150 Watt Laser
    Couple things but lets get right to it.
    I hit reset on the laser itself and now my parameters for the head on the Y axis moving have been limited to a certain area.
    The head will move all the way across on the X axis but on the Y axis it is limited to 900mm and thats only 7" of 37" that im suppose to be able to use.
    How do i fix that so I can use the entire platform?
    I use Thunder Laser software or the RD Works V8.
    I'm am going to start here then I will ask more questions.
    I just want it to get back to where it was before I started messing with stuff
    Thanks so much for your time and help
    Bernie
    Re: Help Please - messed around and my setting are messed up
    Im good this thread can be deleted
    Thanks i will be back with more questions im sure
    Bernie
  1. I messed up microstep step setting.
    By cyberkeith in forum Mach Software (ArtSoft software)
    Last Post: 05-24-2015, 01:14 AM
  2. Machine All messed up
    By Ballnose in forum Bridgeport / Hardinge Mills
    Last Post: 05-20-2013, 03:38 PM
  3. Messed up dimentioning
    By robbinz2121 in forum Solidworks
    Last Post: 02-21-2010, 08:32 PM
