587,035 active members*
3,154 visitors online*
    Mar 2024
    Z height parameter
    HELP!!!
    Our machine has gone a bit funny and the spindle doesn't come to the right height for doing tool changes.
    The Z home height is still perfect, M25 = Z0.0 at Tool change position it is at 116.503 it looks to be around 7mm need to go down is there a parameter i can use to change this?.
    the changer is coming in few millimetres high.
    I know that there is a parameter that tells the machine the distance from the Z home but I don't know what it is or how to get there.
    Aug 2009
    1573
    Re: Z height parameter
    ...might help if, knew what machine you have.
  1. Replies: 0
    Last Post: 02-02-2024, 05:51 PM
  2. Help wiring Tool Height/ Z axis height base into C10 BOB
    By SpecialEd in forum Tormach Personal CNC Mill
    Last Post: 11-21-2016, 02:13 AM
  3. Gauge height parameter settings
    By Matt58 in forum Fanuc
    Last Post: 12-10-2015, 10:26 PM
  4. Fanuc OM Tool Change Height parameter
    By samstain in forum Fanuc
    Last Post: 11-24-2011, 04:56 PM
  5. Replies: 3
    Last Post: 05-28-2009, 01:16 AM
