586,551 active members*
3,317 visitors online*
    May 2009
    1332
    What is Tinned Copper Wire?
    The store I used to buy my cables is gone now so I have to source my cables from the Web. Most say "Tinned Copper Wire". Obviously I want my cables to be copper and not aluminum but what is "Tinned Copper"?
    Nicolas
    Nicolas
    Apr 2018
    133
    Re: What is Tinned Copper Wire?
    Well, if it is REALLY " "Tinned Copper Wire", then its normal copper wire with a layer of what is similar to solder (tin) applied on top of the copper. But in my opinion, some unscrupulous vendors try to pass off aluminum wire as tinned copper. :strange:
    Be careful who you buy from!!!
    Another product to watch out for is so called "CCA", which is aluminum covered with a thin layer of copper. Lots of Cat 5 / Cat 6 Ethernet cable is manufactured with CCA, and some vendors do their best to either not disclose that its CCA, or bury the disclosure in the fine print.
    May 2009
    1332
    Thanks for your time, looks like it's not a good idea to buy cables online unless I know the source which I don't. Will try to find locally even in another town.
    Nicolas
    Nicolas
    Nov 2013
    4431
    tinned copper wire, proper tinned copper wire that is, is expensive.
    In New Zealand, and I guess other jurisdictions, double insulated tinned copper wire is mandatory in any ship that is surveyed. Just the wire alone costs a pretty penny.
    Not really required in ordinary situations, but if it there take it.
    Craig
    May 2009
    1332
    I don’t think you can find on the Web the good quality of wire you are talking about Craig. Hopefully I will find what I want closer to home
    Nicolas
    Nicolas
    May 2009
    1332
    Hi there Craig, how is life in the southern hemisphere?
    When you have the time can you please give me an answer to this post? Been there for a few days with no answers.
    https://www.cnczone.com/forums/mach-...steps-per.html
    Nicolas
    Nicolas
  1. Replies: 0
    Last Post: 02-08-2017, 02:24 PM
  2. USER MANUAL SODICK MARK X or XI wire EDM, and wire breakage
    By stan34 in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2015, 03:56 PM
  3. Copper to copper Welding
    By Masood in forum Welding Brazing Soldering Sealing
    Last Post: 11-19-2012, 05:10 AM
  4. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
  5. Soldering 12 gauge copper wire
    By charper in forum Welding Brazing Soldering Sealing
    Last Post: 03-25-2007, 03:04 AM
