587,013 active members*
3,803 visitors online*
Results 1 to 2 of 2
    Nov 2023
    3
    Vacuum Suction
    I've got a strange problem I absolutely cannot explain.
    Cutting some aluminium composite, completely non porous. Spoil board is 12mm LDF.
    I cut out a letter 'T' roughly 300mm x 200mm, if I place this directly onto the spoil board with all zones open I get a decent hold down force.
    However, if I take the sheet from which the T was cut (using a 6mm end mill) and lay that onto the spoil board and place the T in the cut out section I get absolutely no suction hold down what so ever.
    How can this be? Surely with the sheet on the spoil board effectively acting as a cover board sealing the spoil board the hold down should be increased in the cut out area rather than decreased?
    Any suggestions? Edges are sealed of spoil board and the 'T' is being placed in the same area both with and without the sheet.
    May 2009
    23
    Re: Vacuum Suction
    Is it possible portions of the vacuum grid under the spoilboard are blocked out close to the T area?
    Sent from my SM-P613 using Tapatalk
  1. Replies: 3
    Last Post: 08-17-2023, 06:21 AM
  2. Improving suction on a vacuum table
    By CNC3P0 in forum WoodWorking Topics
    Last Post: 07-07-2019, 10:02 PM
  3. Vacuum pump suction system thoughts
    By zedodia in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-28-2015, 11:15 PM
  4. Will I get more suction with our vacuum hold down by.....?
    By ClickDraw in forum Multicam Machines
    Last Post: 06-04-2015, 07:07 PM
  5. DYI suction (vacuum) machine
    By PipT in forum Engraving Machines
    Last Post: 08-25-2010, 11:03 AM
