586,933 active members*
2,827 visitors online*
Results 1 to 3 of 3
    Serial Connection Problem
    Hello,
    I was using Hyper Terminal on windows XP through a serial port to a '98 Haas VF4 and had no problems.
    Now, I have Hyper Terminal on a Windows 10 computer, trying to connect to the same machine and having problems.
    The XP computer has an onboard serial port, while the Windows 10 computer has a PCIe to serial, but I have tried a USB to serial with no effect.
    When sending a text document over, the program will crash, create random letters, or input the text very slowly without creating a successful connection to the machine.
    When doing this, the machine will display some errors saying that the settings are incorrect , like parity and baud rate, but I have made sure that those are correct.
    Current settings on the machine are below and I have made sure to match those on Hyper Terminal and the actual device port settings.
    Baud rate: 115200
    Parity: Even
    Stop Bit: 1
    Synchronization: Xon/Xoff
    Rs232 Data bits: 7
    Tried lowering Baud to 38400, 19200, and 9600 and same result.
    Is windows 10 just not compatible to communicate with this machine?
    May 2012
    35
    Re: Serial Connection Problem
    It looks like a bad connection in the cable or electromagnetic noises.
    AGG Software. DNC Precision and CNC Syntax Editor software.
    May 2016
    26
    Terminal on Windows 10 should work but it is too complex for this purpose because it is not developed for this purpose.
    I would recommend using a software application specifically designed and developed for CNC connection and communication.
    I use COMMUNICATION SOFTWARE FOR FANUC CNC, which can be used also with other CNCs.
    It has nice built-in help menus that tell you how to connect and how to set the communication data etc.
    You can download from:
    https://www.softpedia.com/get/System...or-FANUC.shtml
    If you still have problems, please contact again.
    HDowns,
    The XP Computer works fine through the same cable. Just when switch over to the Windows 10 computer I am experiencing these problems.
    Let me know if you have any suggestions/ things to try. I've been working on this for awhile and need to get it running. Thanks
  1. k-flop serial connection
    By progsel in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-20-2018, 05:50 PM
  2. Gravograph vx serial connection to PC
    By barty72 in forum Engraving Machines
    Last Post: 12-12-2015, 03:33 AM
  3. 00PC Serial Connection
    By Stupidav in forum Fanuc
    Last Post: 02-05-2011, 06:11 AM
  4. Serial connection
    By Mvu in forum Commercial CNC Wood Routers
    Last Post: 01-16-2010, 03:03 AM
