nstallation method: horizontal/vertical
Model: DGZX-1230
Maximum speed: 30000rpm
Maximum Frequency: 1000HZ
Rated power Kw: 5.5
Maximum voltage V: 380
Rated current A: 15
Maximum current A: 36
Raged torque Nm: 4.4
Bearing: front 7009x2, rear 7007x2
Bearing lubrication method: grease
Cooling method: water cooling
Body outer diameter: 120mm
Overall length of spindle: 487.5mm
Total weight: 27kg
Tool holder: HSK40E
s-l1600 (15) by tivoidethuong, on Flickr
