586,540 active members*
3,001 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Vcarve puts gcode in wrong order for spindle to operate.
    Feb 2024
    I am using Vcarve Pro to make my drawings. When I open the gcode in Mach3, it wont run my spindle. Machine is Industrial CNC Artisan 408
    Gcode is written as S2000M03. Mach 3 wont work until I edit the gcode to say M3S2000.
    I have to do this every time, and know there must be a way to make it work properly every time.
    Post processor I use from Vectric is Mach 2/3 ATC Arcs Inch *.txt
    Thank you.
    Chuck.
    Jun 2005
    1730
    Re: Vcarve puts gcode in wrong order for spindle to operate.
    M3 S3000 is the right order check your post processor other ventricle products work perfect with Mach 3 b Mach 4
  1. Help with Vcarve GCODE Output Needed
    By rphoward in forum G-Code Programing
    Last Post: 01-12-2021, 04:55 PM
  2. VCarve gcode problem!?
    By Smokey930 in forum PlanetCNC
    Last Post: 09-21-2018, 10:25 PM
  3. version 23 machining order using vcarve
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 07-07-2014, 11:49 PM
  4. Laser cutting machine should be how to operate in order to avoid the harm to human bo
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-09-2014, 08:59 AM
  5. Placed an order and PayPal got the wrong shipping address
    By thegimpster in forum Automation Technology Products
    Last Post: 03-05-2008, 04:26 AM
