We have full-time opportunity in Saint Louis, MO.
Job Title: CNC Machinist
Job Type: Full Time.
Summary: The CNC Machinist is responsible for performing duties required to set up and adjust a variety of machines such as drill press, engine lathe, turret lathe, NC lathe, and machining center to perform established and standard machining operations to produce parts such as volutes, butterfly valve bodies, and disks, impellers, etc., utilizing brass, Lewmet, cast iron, or stainless steel. Also, it must deburr parts.
Responsibilities:
Focus Area: Operate machine to prove-out setup and produce pilot workpiece for inspection.
Focus Area: Work from complex blueprints, part drawings, specifications, setup instructions, etc.
Focus Area: Work on multi-tooled arrangements with several operations where very close-dimensional relations are important.
Focus Area: Diagnose machine or tooling malfunction and make the proper and corrective adjustments.
Safety First: Demonstrate 100% commitment to our zero-harm behaviors to support our drive towards developing a world-class safety culture.
Knowledge/Education and Qualifications:
Any equivalent combination of education and experience will be considered for candidates who can perform the objectives above.
GED or High School Diploma required.
3+ years of experience as a CNC Machinist preferred (set up/operator).
Experience working with Fanuc controls.
Knowledge of reading blueprints, rulers, using calibers, and FANUC controls.
To Apply, Here is the link: https://www.linkedin.com/jobs/view/3817766381/
