587,080 active members*
3,266 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > mach3 error g code rhinocam
    Feb 2024
    6
    hello, I just asked you for help, I am trying to machine a part in 5 axis BC, as in the photo, when I look at the simulation the parts are machined correctly, put when I put the gcode in mach3, I have an error no digits found where real number should be block number, what is this coming from?
    Attached Thumbnails Attached Thumbnails Capture d’écran (62).jpg   Capture d’écran (63).jpg   Capture d’écran (64).jpg   Capture d’écran (65).jpg
    Dec 2008
    3122
    Re: mach3 error g code rhinocam
    Only guessing
    You have an A output(around X) in the programming... but you have a B axis (around Y) in the machine configuration.
    Feb 2024
    6
    Quote Originally Posted by Superman View Post
    Only guessing
    hello, thank you for answering me, for the output which was in A in programming I changed it to B I had a little trouble finding it was in the setting of the post proc ess of rhino, on the other hand I have another problem , these are the orientation of the setup in the programming of rhino, if I give you my file of my parts can you program it correctly for me please, so that I understand where my error comes from, because here I am eating the brain
    Feb 2024
    6
    and I just saw there is no output in axis C in the g code, I put axis C in segondary, is there anything else changed?
    Feb 2024
    6
    hello, thank you for answering me, I changed the output in post processor setting to B but I see nothing in C I select them in secondary, do we need to add something in sample output or something else? and I have an orientation problem in the programming of the setup, I put the part in link if you or someone can program me the second side of the part in 5 axis https://www.file.io/qOSA/download/PecjzIwzrMzE , I did the first, that I understand where it comes from the problem.I just took screenshots of the orientation, the problem is that in setup select I cannot orient the parts correctly for the 2nd side of the machining
    Attached Thumbnails Attached Thumbnails Capture d’écran (66).jpg   Capture d’écran (67).jpg   Capture d’écran (68).jpg   Capture d’écran (69).jpg
    Feb 2024
    6
    I managed to activate output C,It remains to be seen how it behaves, and that I learn to correctly orient myself in programming, know what type of machining program is needed, for different operations,... there is still some work to be done, but I like it.
  1. Rhinocam mach3 query
    By marbles in forum Rhinocam
    Last Post: 12-13-2019, 09:49 PM
  2. Mach3 reading fusion 360 g-code as error
    By mcdoggie in forum Machines running Mach Software
    Last Post: 08-10-2017, 05:49 AM
  3. RhinoCam does not code MCS change
    By AussiHorologist in forum Rhinocam
    Last Post: 04-03-2012, 01:01 PM
  4. Replies: 17
    Last Post: 06-01-2011, 12:48 PM
  5. Anyone else using RhinoCAM for g-code generation?
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 07-21-2010, 04:34 AM
