586,677 active members*
3,098 visitors online*
    Post Cnc Getting Stuck before start of cut?
    Hi All,
    I'm new to this forum and hope I'm posting in right place.........
    Ok so today, i start my router up, like every other day.
    But today i run my router through spoil board code as my surface needs a clean.
    Here's where my issue starts.
    1- Do a code for a larger spoil board
    2- I forget to change my controller Soft limits(not a problem as my hard limits are nowhere near.
    3- so code starts cuts as normal, until it hits my soft limit.
    4- I realize straight away what I've done in No2. change all necessary soft limit setting's.
    5- home machine Bla bla bla......
    6- Start code...spindle moves to position, spindle starts gets to speed, rapids down to 60,27.5,5 spindle still running........and thats where it stays.
    here's the piece of code, where it gets stuck.
    T1M6
    G17
    G0Z20.000
    G0X0.000Y0.000S16000M3
    G0X60.000Y27.500Z5.000
    G1Z-0.500F750.0
    G1X59.544Y27.503F1800.0
    X59.085Y27.513
    X58.623Y27.529
    X58.160Y27.552
    X57.694Y27.582
    X57.226Y27.619
    I've just put that space there to show where its getting stuck....
    I'm Baffled tried numerous toolpaths 3 different cam software still gets stuck there just spinning away....
    any help would be appreciated......
    Nov 2007
    353
    Re: Cnc Getting Stuck before start of cut?
    So it doing the rapid ok and spindle on ?
    Is the feed switch ok ?
    Why no H value for tool offsett or G54/59 for fixture ?
  1. Looking for a CNC Router to cut Hard Maple- Where to start?
    By tfeek in forum Commercial CNC Wood Routers
    Last Post: 08-26-2016, 07:47 AM
  2. CNC to cut metal - Where to start?
    By hhjj7777 in forum Want To Buy...Need help!
    Last Post: 06-20-2016, 09:06 PM
  3. Replies: 0
    Last Post: 11-28-2013, 08:01 AM
  4. TNC 310 program gets stuck after spindle start
    By danielhermle in forum HEIDENHAIN -> TNC
    Last Post: 10-02-2011, 01:14 PM
  5. Cut speed is stuck at Slow????Mach 2
    By mwalach in forum Mach Mill
    Last Post: 08-24-2006, 12:58 PM
