587,019 active members*
4,094 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Exporting dxf files into cnc software
Results 1 to 14 of 14
    Feb 2024
    Hello can someone please assist me? When I upload my dxf files they are missing sized (to large or of of working area) when I upload them I'm using planet cnc software I just need to learn how to put the files into the correct size and into the modeling area so I can machine them properly.
    Many thanks and greatly appreciated some advice!
    Nov 2013
    4469
    Re: Exporting dxf files into cnc software
    .dxf files are drawing files, not Gcode. CNCsoftware controllers like PlanetCNC use Gcode to describe machine motion.. You need a program that can convert a drawing (dxf) into Gcode.
    Such programs are called CAM, Computer Aided Manufacture. The oldest and probably still the best is MasterCAM. If you have to ask how much it is then forget it......it costs a bloody
    fortune.
    I use Fusion. I pay a yearly subscription because I like it and want to access all its features, but Fusion is free to hobbyists and startups. I believe it has the capacity to import dxf
    files and thereafter produce Gcode.
    Craig
    Feb 2024
    I use Fusion 360 and can upload the dxf into the cnc software to read g-code fine my problem is when I upload my dxf file into the cnc software my project is too large and I'm not sure how to adjust it from that point in the system. Thank you for your help!
    - - - Updated - - -
    - - - Updated - - -
    Jul 2018
    6451
    Hi Treeman - What do you mean by "its too large" haven't seen that issue before... Send the error code and example to fusion support. They have answered my questions very quickly... Peter
    Dec 2008
    3122
    Quote Originally Posted by Treeman77 View Post
    I think Craig thinks you are "driving" your machine from the DXF file...
    DXFs are created in position & size with the originating CADware.
    It is in your software that you need to adjust the design. To resize. Look for "scale" where 100% is current size (some CAD may use 1 as current size). Usually it scales around the screen origin point (you might be able to select a different focus point).
    After scaling, you then "translate" (move it, mirror, rotate etc) into a zone suitable for programming your toolpaths. Your stock size is created relative to your origin, & your design is placed within this stock.
    Feb 2024
    Thank you I'll check this out and work on it I'm new to cnc I appreciate your help!
    Jan 2017
    You may also be dealing with improper units.
    I ran into that before.
    If the drawing is in mm but in the import screen you tell it that units are inches, it will import 25.4 times larger and appear huge in the working area.
    Just a thought.
    Mar 2017
    1327
    DXF files are "unitless". They do not contain any units.
    When importing user must choose Metric or Imperial units and correct Scale factor
    Dec 2008
    3122
    Quote Originally Posted by PlanetCNC View Post
    Nah.... I dont believe this. It does know what units the DXF was created in.
    If I do a CAD drawing of a 1" cube, export a DXF
    Now open that DXF into a different CAD system (default is millimetres) it will be a 25.4mm cube... not a 1mm cube
    Mar 2017
    1327
    If you don't believe that doesn't make it true. DXF is unitless and that is a fact.
    Apr 2018
    134
    I thought I would provide a link to an independent 3rd party to weigh in on this.
    Imported DXF or DWG file in Fusion is not correctly scaled
    Autodesk Support
    Jan 12, 2024
    Products and versions covered
    Issue:
    The scale of a DXF or DWG file imported into Fusion is incorrect.
    Causes:
    • A DXF file is a unitless file type so when Fusion reads the file, by default. It will assume that the file is in centimeters unless otherwise specified during insertion.
    • A DWG file is exported with unit-less settings in the units in AutoCAD
    Link: https://www.autodesk.com/support/tec...ect-scale.html
    Autodesk is the publisher of a variety of popular products, including Fusion and AutoCad.
    Dec 2008
    3122
    Quote Originally Posted by RaderSidetrack View Post
    Ok ... can you guys explain this link
    https://ezdxf.readthedocs.io/en/stable/concepts/units.html
    This was seen in various docs explaining units, so I am assuming a generalised example.
    Yes... the header area is unitless, but the dimension area HAS units
    It sets the modelspace layout to the setting in $INSUNITS, then creates the objects to to those units (or scales it to match the import target layout).
    It has to know what units the screen objects are before importing & displaying.
    Mar 2017
    1327
    ...can you guys explain this link...
    The DXF reference has no explicit information how to handle units ...
    Some programs use $INSUNITS property (like BricsCAD) for units but this property is actually used for something else.
    https://help.autodesk.com/view/ACD/2...A-EEF55A2B4FD8
    In the last 30 years I opened and examined thousands of dx files. Most of them don't even have INSUNITS property. That is why an option to select units and scale is there.
    Mar 2017
    1327
    But perhaps more programs now use INSUNITS property.
    I'll implement automatic unit detection based on this property. It is trivial task.
    This is what I'll do.
    Code:
            switch (dxf.Var_INSUNITS)
                case 0: { break; } // Unitless
                case 1: // Inches
                    _Param->DataUnits = Units::Inches;
                    _Param->Scale = 1;
                    break;
                case 2: // Feet
                    _Param->Scale = 12;
                    break;
                case 3: // Miles
                    _Param->Scale = 63360;
                    break;
                case 4: // Millimeters
                    _Param->DataUnits = Units::Millimeters;
                    _Param->Scale = 1;
                    break;
                case 5: // Centimeters
                    _Param->Scale = 100;
                    break;
                case 6: // Meters
                    _Param->Scale = 1000;
                    break;
                case 7: // Kilometers
                    _Param->Scale = 1000000;
                    break;
                case 8:// Microinches
                    _Param->Scale = 0.000001;
                    break;
                case 9: // Mils
                    _Param->Scale = 0.001;
                    break;
                case 10: // Yards
                    _Param->Scale = 36;
                    break;
                case 11: // Angstroms
                    _Param->Scale = 0.0000001;
                    break;
                case 12: // Nanometers
                    break;
                case 13:  // Microns
                    break;
                case 14: // Decimeters
                    break;
                case 15: // Decameters
                    _Param->Scale = 10000;
                    break;
                case 16: // Hectometers
                    _Param->Scale = 100000;
                    break;
                case 17:// Gigameters
                    _Param->Scale = 1000000000000;
                    break;
                case 18: // Astronomical units
                    _Param->Scale = 1.496e+14;
                    break;
                case 19: // Light years
                    _Param->Scale = 9.461e+18;
                    break;
                case 20: // Parsecs
                    _Param->Scale = 3.086e+19;
                    break;
                case 21: // US Survey Feet
                    _Param->Scale = 1200000 / 3937;
                    break;
                default:
                    break;
  1. HVAC Software to export DXF files
    By Joe Jones in forum Uncategorised CAD Discussion
    Last Post: 09-23-2016, 03:28 AM
  2. Replies: 2
    Last Post: 03-06-2013, 08:40 PM
  3. Exporting DXF Files - Dimensions not visible
    By jwreeddesign in forum Solidworks
    Last Post: 02-20-2013, 07:49 PM
  4. Software that exports dxf files?
    By Danny B in forum Uncategorised CAD Discussion
    Last Post: 03-28-2011, 03:28 PM
  5. Problems exporting Corel text files as DXF
    By CustomConcepts in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-21-2008, 07:24 PM
