586,160 active members*
3,509 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Z axis will not move with chuck unclamped. Bar Puller.
    Feb 2024
    Question Z axis will not move with chuck unclamped. Bar Puller.
    2006 Mori Seiki NL2500
    Bar Puller used to work. Now the Z axis will not move with chuck unclamped (after M11).
    This used to work...
    G97S100
    G0G54X0Z-.250
    G1Z-.950F80.
    M11
    G1Z-.450F80.
    M10
    I set the red light sensors at the back of the spindle to every combination of 'on' or 'off', this did not work.
    I changed the 'chuck1 clamp direction from od chucking to id chucking' in Operation Panel, this did not work.
    I need help solving this issue.
    Do you have any suggestions?
    Wayne
    Feb 2024
    Re: Z axis will not move with chuck unclamped. Bar Puller.
