586,724 active members*
3,635 visitors online*
    Dec 2020
    Conquest GT27SP
    I have a GT27 SP I amblooking at buying. I would get it today except that the dealer is havingvtroiblr showing me that the C Axis is functional. There is a build sheet that shows 1 degree increments on C is available. They can't seem to get ut to go. Is there a parameter setting or special G Code associated with that function?
    Sent from my LM-V600 using Tapatalk
    Dec 2008
    3112
    Re: Conquest GT27SP
    You may have to enable "milling mode" to interlock C to the handwheel.
    Dec 2020
    Re: Conquest GT27SP
    That would be a parameter setting correct? I have a list of 900-920 parameters. Is it found there?
    Dec 2008
    3112
    Quote Originally Posted by blmac515 View Post
    I would think it was a panel push button, or M code to turn ON and a different M code to turn OFF.
  1. conquest,
    By onestopjim in forum Hardinge Lathes
    Last Post: 10-07-2016, 11:40 PM
  2. Hardinge GT27SP wirring needed
    By dango in forum Hardinge Lathes
    Last Post: 08-16-2012, 11:18 AM
  3. Harding GT27SP livetooling
    By dango in forum Bridgeport / Hardinge Mills
    Last Post: 01-17-2012, 04:33 AM
  4. Need help with conquest 10-65
    By dfrey2@rocheste in forum Hardinge Lathes
    Last Post: 09-27-2011, 01:00 AM
  5. Remastering a Conquest GT27sp
    By joeski63 in forum Hardinge Lathes
    Last Post: 09-12-2011, 08:49 PM
