586,537 active members*
2,969 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Calibration / Measurement > Can someone help me understand depth gauges?
    Nov 2018
    Hey everyone
    I’m in the process of buying a depth gauge, most likely a digital version, which I’ll be using to set up gears in a 12 bolt rear end.
    I understand the general concept from 0-1”, but since my measurements will be from 2”-5” I’m a bit confused.
    I see guys on YouTube using gauge blocks to set the dial indicators to zero when they add extensions to the original indicator plunger once they are measuring past 1”.
    If that’s the case, you’d need tons of different gauge blocks to get a zero reference depending on how deep you’re measuring, correct? Or maybe I’m just an idiot and don’t understand the concept of adding extensions to the gauge.
    I don’t want to invest in one of these until I understand how to use it obviously.
    Can anyone help clarify how to set these up when using extensions?
    Much thanks in advance!
    Dec 2008
    3110
    Re: Can someone help me understand depth gauges?
    You can purchase gauges for a dedicated range (ie... 0-1" or 0-25mm)
    Or obtain sets for a larger range (ie... 0-6" or 0-150mm)
    See link, the thimble separates between the knurl & zero indicator to exchange the depth pin
    https://www.raptorsupplies.com.au/pd...xoCbtgQAvD_BwE
  1. Does anyone use temperature gauges for your drivers?
    By slashmaster in forum Benchtop Machines
    Last Post: 01-25-2017, 07:44 PM
  2. Have parts, need to wire, what gauges to use?
    By mmedina1976 in forum CNC Machine Related Electronics
    Last Post: 11-28-2014, 06:15 PM
  3. Replies: 2
    Last Post: 02-04-2012, 05:27 PM
  4. Check gauges borrowing
    By HIMSELF in forum SERVICE FOR CNC-MACHINES
    Last Post: 09-30-2008, 03:47 PM
  5. Using Gauges in CamSoft
    By Steve Etter in forum CamSoft Products
    Last Post: 11-12-2003, 08:58 PM
