Hi, i'm currently working in a company with an old Trumpf laser. They cut mild and stainless steel sheets from 1 to 5 mm. I program the cut on a PC where there is TruTops Software (version 5). Every time i assign a cut table to a cut program and i send it to laser PLC via server. On the laser i can see the cutting parameter write in the cut table i used. I can change that parameters and create a new chart too.
But i'm not able to see that new table on the programming PC to assign it to future programs.
How can i manage new tables on the programming PC, with trutop I suppose...?
Thank you
