586,693 active members*
2,959 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Handel and jog mode low spindle RPM . Help
    Apr 2014
    5
    Hallo
    I have a problem with a cnc model vmc1000b from smtcl with fanuc oi.md. model 2014.
    ON MDI mode if i set a spindle rpm ex:1000 and i go to handle or jog mode the rpm change to 200rpm and cannot be changed. Is like a safty setting from parrameter.
    What is the reason for this and how can be changed?!
    Thanks in advance.
    Apr 2014
    5
    Re: Handel and jog mode low spindle RPM . Help
    From.smtcl i have a message that sugest to change parameter d55. Where I can find this ?! I know where parameter are and how to modify it but I never see a parameter with letters.
    Dec 2009
    964
    look in PMC-DATA TABLE,where are the timers,counters,keeprelay
  1. Replies: 4
    Last Post: 11-12-2022, 02:01 AM
  2. Spindle Rpm too low
    By robjeffking in forum Avid CNC
    Last Post: 12-02-2020, 05:02 PM
  3. Spindle rpm slow down when jog any axis (Mach3)
    By SAMI81 in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2019, 05:10 AM
  4. Hardinge Conquest T-42 spindle will not rotate in jog mode
    By DannyP in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2011, 05:01 PM
  5. Low RPM Spindle
    By kolias in forum DIY CNC Router Table Machines
    Last Post: 03-04-2011, 06:40 AM
