586,544 active members*
2,853 visitors online*
    Jun 2016
    57
    VH65 BOLT PATTERN
    On a VH 65 rotary, what is the bolt hole pattern drilled in the faceplate?
    I don't see it in any of the documentation.
    Sep 2009
    103
    Re: VH65 BOLT PATTERN
    The center locating bore is 1.625" at .25 deep.
    Bolt circle options are;
    1/4-20 on 2.345 b.c. 4 pls.
    3/8-16 on 4.125 b.c. 4 pls.
    1/4-20 on 5.34 b.c. 6 pls.
  1. Circular bolt pattern wizard question
    By SwampDonkey in forum Mach Wizards, Macros, & Addons
    Last Post: 09-01-2013, 06:14 PM
  2. Circle With Bolt hole Pattern
    By JJsFab in forum Torchmate
    Last Post: 09-01-2013, 06:07 PM
  3. Bolt hole pattern for Fanuc 18i
    By J.D.R in forum MetalWork Discussion
    Last Post: 01-31-2009, 11:33 PM
  4. programming bolt hole pattern
    By jrogus in forum CNC Machining Centers
    Last Post: 05-23-2008, 07:23 PM
  5. 200oz in Motor Bolt Pattern
    By jhwatts in forum Hobbycnc (Products)
    Last Post: 10-13-2005, 03:40 PM
