586,129 active members*
3,070 visitors online*
IndustryArena Forum > Community Club House > Nuts are driving me nuts!
Results 1 to 10 of 10
    Help me! I need to buy a single M15x1 locknut but can't find anyone that sells them.
    Also needed is a 15mm flange mount bearing. Also very hard to find.
    Proud owner of a Series II Bridgeport.
    Apr 2004
    678
    Try talking to a car mechanic working on Japanese and European cars.
    That seems an odd dimension, but it may be used on a generator shaft.
    Sep 2003
    363
    Try Fastenal, they have stores everywhere and have almost any kind of fastener.
    Gary
    Jun 2004
    Most unusual threads as in the case of a M15x1 nut are generally not available. It may be a good idea to check a Machineries Handbook to see if it’s a standard of some sort, (its possibility a conduit thread). Your two alternatives are to bye a tap from an industrial hardware, they can also have one custom made to your specifications, and make a nut. Or to screw cut one yourself if you have a screw cutting lathe. Another alternative is to replace the bolt to suit a more standard thread style, avoiding the problem altogether.
    Best of luck Mark
    It's a thrust bearing thread on a ballscrew (hard to replace). I don't have access to a lathe right now.
    Jun 2004
    487
    Perfect. Any idea how to order them? They look like there oversees.
    Jan 2004
    87
    Upper left hand HLB15
    http://www.misumiamerica.com/usacata...tric/p0317.pdf
    Here is the main page. Order the catalog!
    www.misumiamerica.com/usacatalog/doProcess
    Mark
    DMG Designs
    League City, Texas
    Jun 2004
    487
    Yep, they're in Korea.
    Here's how to order:
    http://www.finemall.co.kr/guide_e.htm
    Apr 2003
    These nuts are available in the US. Try www.Metricmcc.com. Look under 981 lock nuts. The nut is a km2. they are $3.60 each but there is a minumum.
    Dick
  1. Anti - Backlash Nuts
    By Mhiran in forum DIY CNC Router Table Machines
    Last Post: 02-18-2010, 02:55 PM
  2. Spinning nuts!
    By turmite in forum DIY CNC Router Table Machines
    Last Post: 05-06-2004, 03:17 AM
  3. Nuts; I'm thinking about my nuts
    By Stevie in forum Uncategorised MetalWorking Machines
    Last Post: 02-29-2004, 12:55 AM
  4. M12 x 1 nuts needed
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 02-28-2004, 01:22 AM
  5. Lost my nuts!
    By kong in forum DIY CNC Router Table Machines
    Last Post: 08-18-2003, 06:56 PM
