587,043 active members*
3,020 visitors online*
Results 1 to 2 of 2
    Feb 2023
    21
    Tangentail Cutting Head Motor Spec
    Hi Friends,
    I'm not sure if this is the right place for this question but it seemed close.
    I am in the middle of designing a tangential cutting head for a CNC I am building. I plan to have the cutting head have a servo motor and i am working on spec'ing that motor now. For the machine I am using a super fancy kit I got from china, Bulkman 3D that came with and outdated control system (mach3) and what i am learning might be not standard/good/decent motors. I am using a RP4 and a Mesa 7i96 that I have LCNC running on but still need to talk to the Mesa (separate thread to come later lol) to run the basic code stuff based on a recommendation from a different post.
    I would ideally like to not upgrade any power supplies ill my probably foolish problem below:
    Supplied Power Supplies
    1- 52.8 W @ 24V
    2- 348 W @ 24V
    Total Power = 400 W @ 24 V (16.6 A calculated)
    Supplied Motors:
    4 x Rated Voltage - 3.6 V
    Rated Current - 3A
    It would seem at peak the motors that control the XYZ axis' will consume 3A * 4 = 12A, so i should have up to 16.6 A - 12A = 4.6A minus some safety factor to work with? Is this correct or do i need to review my circuits notes?
    Where i get hung up is the voltage and this might be a misunderstanding of the stepper drivers but i find some that fit my requirements (nema 23 frame size and 0.25" shaft with encoder) that vary from as low as 2.6 up to 24 V. Below are some of the ones that i am looking at but i feel like i might be missing/ not considering something here. Does any of this matter or does the magic happen in the stepper controller?
    24-80 V
    https://www.mouser.com/ProductDetail...FJ6olrdQ%3D%3D
    2.3 V
    https://www.mouser.com/ProductDetail...6iHymguA%3D%3D
    Kit I am planning on attaching the head to (minus UC300 and mach 3, plus RP4, Mesa Card, and LCNC)
    https://bulkman3d.com/product/queenb...-rail-upgrade/
    Any help is greatly appreciated!
    Feb 2023
    21
    Re: Tangentail Cutting Head Motor Spec
    Just found the "Stepper motors and Drives" topic and i am going to copy and past this question there. Thanks
  1. stepper motor spec
    By francoismongeau in forum Stepper Motors / Drives
    Last Post: 03-07-2017, 02:40 AM
  2. Maxon Motor Spec
    By benjammn in forum Servo Motors / Drives
    Last Post: 08-31-2010, 06:45 PM
  3. Stepper motor spec?
    By benergy in forum Stepper Motors / Drives
    Last Post: 01-28-2008, 11:26 PM
  4. Engraving, Tangentail arcs, and crop circles
    By Prboz in forum BobCad-Cam
    Last Post: 06-29-2007, 02:06 AM
  5. Motor Spec's
    By 69owb in forum Servo Motors / Drives
    Last Post: 01-08-2006, 11:18 PM
