586,634 active members*
2,972 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA L470 Spindle rpm dropping
    So we were having a trouble on shop. When facing, the roughing tool is making a grooving on the part. We have also encountered the same unwanted grooving while using a boring bar on tapered section of a part.
    I noticed that the spindle rpm was winding down and up while machining which is very unusual because our programs are already proven before.
    Our maintenance said it might be the bearings of the spindles are shot so they may have to replace the whole spindle or just buy another machine.
    I am really curious on what happened and what might cause this issue. Anybody ideas?
    Mar 2009
    1982
    Re: OKUMA L470 Spindle rpm dropping
    check bearings
    check the attack angle of cutter against the spindle axis
  1. Specifying V-Grooves
    By elfrench in forum Uncategorised CAD Discussion
    Last Post: 08-10-2013, 09:45 AM
  2. grooves
    By matzeKlueber in forum Fanuc
    Last Post: 10-27-2011, 11:40 AM
  3. V Grooves!
    By granth3 in forum CNC Tooling
    Last Post: 10-18-2011, 10:19 PM
  4. What are Z grooves?
    By rezcar in forum Benchtop Machines
    Last Post: 12-12-2009, 08:13 AM
  5. Oil Grooves
    By gmilosevic in forum Want To Buy...Need help!
    Last Post: 02-24-2008, 12:03 PM
