Hello, I have a question regarding using a stepper motor to produce electricity.
Quick back story, I had a motor for an Ebike lying around wondering what to do with it, thought to myself that might make a nice small generator for something, but how to turn it.
So I built some blades which should be more efficient than conventional VAWT blades, then at work saw a phone charging station and thought BINGO, I'll use the motor for the phone charger.
After marrying the motor and the blades, i tested the turbine in front of an industrial ventilator, and hoping for ca 12 volts, at a wind speed of 25km/h, the motor actually produced a disappointing 2-3 volts.
After doing some research, it became blatantly obvious that a planetary motor as used in the ebike motor was the worst type of motor to use in this situation, but in fact a stepper motor is the ideal motor to use.
The motor I got was a Nema23 1.9Nm 5A 2 phase motor, (What other specs should be known).
I built a bridge rectifier for each phase, and wired those in series to convert AC into DC.
The cogs used gave a 2:1 ratio (40 teeth on the turbine side, 20 teeth on the motor side)
At 25km/h produced 4-5 volts, but of course was turning ultra slow.
I then made a cog with ca 500 teeth and the motor spins significantly faster, but it's also significantly harder to spin.
Without the motor connected, the turbines spins freely with little resistance, but with the motor, there is no free spinning.
At this stage, i havnt tested it with the ventilator, just spinning by hand, but I'm fairly confident at 25km/h I'll get 12 volts.
I'm worried that the wind speed to get the turbine spinning will be high.
My question is, in this situation, how big of a role does the torque play in the motor spin easier?
If it does play a role, can anyone recommend a motor that is more suited?
Or is it better to just halve the size of the turbine cog?
Thanks in advance
