586,149 active members*
3,630 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Engine to bellhousing adapter plate template creation
    Jan 2024
    Message please excuse me I'm absolutely lost here but what I'm looking for is to make an adapter plate to drill and tap or through hole for an automobile engine to an automobile bellhousing to put a different transmission onto the motor I know it can be done I've seen it they're out there but I'm not that mechanically drawn type individual I'm going to try to include a picture of what I'm talking about and some technical specs on the motor and the transmission I'm seeking to overlaye
    https://www.google.com/imgres?imgurl...1a561adf356a97
    Jan 2024
    Re: Engine to bellhousing adapter plate template creation
    My bad it's a 1996 Lincoln 4.6 l dual overhead cam front wheel drive rear of the motor bellhousing mount and it would be for I suppose it's a small block Ford before 70 I believe transmission coming in the f-150s I believe also mustangs could be also an aod or an aod is in Eric thank you in advance
