586,501 active members*
3,333 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Buying a new Chinese blue elephant cnc atc router
Results 1 to 1 of 1
    Jan 2024
    4
    Question Buying a new Chinese blue elephant cnc atc router
    Hello brothers I’m new to buying cnc machines and am starting a new business of parametric wood furniture and have selected to buy a blue elephant cnc 3axis atc router with the following specs, can i get some advice on the specs? If they are ok or do I need to change anything. I would be using birch plywood sheets 120mmx240mm having thickness of 18to24mm to make parametric furniture like benches, reception desks, shelves etc,
    This is the configuration of ELECNC1325 ATC:
    Working area 1300*2500*200mm
    9KW Italy HSD ATC air cooling spindle, 24000RPM
    SYNTEC 6MB control system
    850W Japan original YASKAWA servo motor
    11KW Fuling inverter
    8 pcs carousel tool magazines
    Japan Shimpo reducer
    #25 Taiwan linear guide
    Auto oil lubrication system
    Japan OMRON limit switch
    T-slot & vacuum working table
    7.5KW air type vacuum pump
    3KW dust collector with double bags
    (Including plywood package)
    Nov 2011
    261
    Re: Buying a new Chinese blue elephant cnc atc router
    Hello sir, we are Blue Elephant CNC. Very glad you can choose us. You can customize the configuration of the machine as needed. If you are not sure, you can ask our sales staff and designers.
    Here is our contact information:
    https://www.elephant-cnc.com/
    Email: [email protected]
    Whatsapp/mobile: +86-15064026772
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
    Jan 2024
    I think the specs look good. How much is it quoted for?
    Nov 2011
    261
    For more machine information and quotation, we will let our professional sales tell you.
    Can you leave me your email or whatsapp?
