Find the section in the post that you want the output. Most likely this will be the ptlchg section of the post. Find the line where you want to force out the block number. Find the "n," in that line and replace it with a *n, "n" is the variable for the block number and the * forces the output of that variable. Then make sure the omitseq variable is set to yes (or 1).
You you've turned off block numbers, except for that one place where you're forcing them out.
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
