586,948 active members*
2,345 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Send and Receive file with Fanuc Series 18i-MB
    Hello, we have a client who transfers data from an old CNC with RS232 to a computer via a serial cable. They are asking us for a way to reach the CNC machine remotely from other computers. We have installed a MOXA NPort 5150 and configured it with the same serial settings as the CNC machine. I tried to open it with Windows Explorer using the IP address, but it shows nothing.
    How can I transfer the data between a PC and CNC machine? Do I need to install any other tools to achieve this?
    Aug 2009
    1573
    Re: Send and Receive file with Fanuc Series 18i-MB
    ...I think the RealCom Mode is what you need to use. Then, each PC install a RealCom Port with NPort Admin program IF, I remember correctly.
    https://www.moxa.com/en/products/ind...ries#resources
    DJ
    There also I see a Firmware update 2022 V3.10
    Hi, thanks for the reply.
    I never worked with CNC machines.
    Do I also need any software to be able to read and write file from the CNC fanuc?
    - - - Updated - - -
    Dec 2009
    967
    Use Program transfer tool from Fanuc for file transfer,is a drag and drop software ,it is cheap ,around 20 euro and is the easy and safe way to transfer files between CNC nad PC
    May 2016
    26
    I’m using COMMUNICATION SOFTWARE FOR FANUC because it is more powerful and also because it can be used with serial communication RS232.
    It is specially designed for FANUC CNC though it can be used also with other CNC.
    It has several built-in help menus that show you how to use it with your CNC.
    You can download it from “The SOFTPEDIA· web page.
  1. Replies: 1
    Last Post: 03-25-2022, 03:52 PM
  2. Fanuc 11t RS232 send/receive
    By Motorsports-X in forum DNC Problems and Solutions
    Last Post: 03-25-2022, 02:27 PM
  3. File send/receive problems
    By danu37 in forum Milltronics
    Last Post: 07-09-2014, 07:48 PM
  4. Remote send/receive
    By 2hoop4inch in forum Haas Mills
    Last Post: 05-28-2009, 12:21 AM
  5. WIRELESS send & receive
    By SpeedMetal in forum Milltronics
    Last Post: 01-21-2008, 11:04 PM
