586,745 active members*
6,617 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > 770 series 3 with mach OS change motherboard battery
    Nov 2012
    68
    My 770 series 3 won't turn on with the power switch at the console anymore, just started. I now have to go under the machine base where the control computer is and push the on button every time. I was told on another forum I need to change the battery in the mother board in the computer.
    Has anybody had this issue and if so how do you get to the mother board. I assume I need to take the cover off the computer but is there any tips for me. Thanks
    Nov 2022
    12
    This doc covers how to replace the battery on a bunch of the controllers.
    http://tormach.com/battery
    Nov 2012
    68
    Re: 770 series 3 with mach OS change motherboard battery
    This doc looks to be for a path pilot controller. I have the older Mach OS. I'll pull it out this weekend and take a look. Maybe its the same. Thanks for your help.
    Jun 2005
    656
    Quote Originally Posted by joeyjrc View Post
    It's going to be a regular PC of some sort in there. Might be unbranded but its usually pretty easy to remove the outer case and find the CMOS battery once you get the PC out. The "legacy controller" info in the doc will be most useful.
    Nov 2012
    68
    I fixed it. The control computer's cover was easy enough to remove but the battery was not in an easy to get to spot. Pain in the neck, I had to tape it to a tool and carefully operate on that sucker.
    I got it finally and it solved the problem.
    Thanks for the advice.
  1. Anilam 1100 motherboard battery replacement
    By SoggyBottomBoy in forum CNC Machine Related Electronics
    Last Post: 04-26-2021, 09:47 PM
  2. Replies: 3
    Last Post: 12-14-2020, 12:34 PM
  3. Ez trak battery location on motherboard
    By nealg in forum Bridgeport / Hardinge Mills
    Last Post: 07-14-2015, 04:07 AM
  4. Battery change and initializing position _ NL series
    By aidenkim in forum Mori Seiki lathes
    Last Post: 08-26-2011, 02:28 PM
  5. Motherboard battery(?) issues, Partner 4 CentV
    By trevj1 in forum Milltronics
    Last Post: 02-26-2011, 07:41 AM
