586,500 active members*
2,486 visitors online*
    May 2009
    1332
    Grounding VFD
    I had to relocate my CNC control panel and this required to re wire my 120VAC VFD model HY020211B. The VFD has 3 terminals R,T,E for the 120VAC input Black, White and Ground wire. For the output to the water cooled spindle the VFD has U,V,W plus the Ground terminals.
    Do the grounds of both 120VAC input to the VFD and output to the spindle end at the same place? (that is the 120VAC ground).
    Nicolas
    24223
    Re: Grounding VFD
    Yes, normally you would set up a star ground point that includes the system Earth conductor.
    Both VFD GND ands the VFD cable shield would be connected at this point.
    There is also a recommendation by Siemens to carry out equi-potential bonding, this as all metallic parts of the machine be bonded to an earth conductor.
    I have posted the Siemens paper here a few times.
    Apr 2018
    133
    Re: Grounding VFD
    See post #11 in this thread:
    https://www.cnczone.com/forums/cnc-m...ml#post2535116
    May 2009
    1332
    Re: Grounding VFD
    There is also a recommendation by Siemens to carry out equi-potential bonding, this as all metallic parts of the machine be bonded to an earth conductor. I have posted the Siemens paper here a few times.
    Many thanks Al
    Nicolas
  1. Grounding improvements after adding VFD?
    By sploo in forum CNC Machine Related Electronics
    Last Post: 03-24-2021, 04:24 PM
  2. Replies: 86
    Last Post: 02-09-2019, 02:44 PM
  3. Controller Enclosure and VFD Enclsoure Grounding
    By Kent23 in forum CNC Machine Related Electronics
    Last Post: 11-30-2016, 04:21 PM
  4. Grounding a 2.2kw VFD spindle
    By DDMODS in forum Spindles / VFD
    Last Post: 07-21-2016, 11:28 AM
  5. Enclosure / VFD / Grounding / EMI
    By mturneruk in forum CNC Machine Related Electronics
    Last Post: 11-29-2015, 02:25 AM
