586,847 active members*
2,290 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > Multicam 3000 - Drive is working in reverse
    Jan 2024
    Lightbulb Multicam 3000 - Drive is working in reverse
    Due to drive failure I had to connect a different drive. When it comes home on the Z Axis, it goes down and hits the counter and gives an error. Can I fix the reverse movement of the drive?
    https://youtube.com/shorts/BTcctH5K2FI?feature=shared
    Jun 2010
    463
    Re: Multicam 3000 - Drive is working in reverse
    You have to program the drive to the correct axis, you might be able to call Multicam for the drive parameters.
    You will need the teknics communication software and cable to talk to the drives or if your machine has the 2125 and newer control board you may be able to use the controller to reprogram the drives.
  1. multicam 3000
    By sawdust66 in forum Multicam Machines
    Last Post: 05-28-2022, 05:37 PM
  2. MultiCam 3000 Xa servo drive motor
    By albox in forum Multicam Machines
    Last Post: 04-27-2022, 04:21 PM
  3. MultiCam 3000
    By Rusty48 in forum Multicam Machines
    Last Post: 01-09-2022, 02:10 PM
  4. Multicam 3000 help anyone?
    By murfeedean in forum Multicam Machines
    Last Post: 05-22-2013, 05:02 PM
  5. Multicam 3000 Nightmare
    By angelocmp in forum Waterjet General Topics
    Last Post: 08-30-2007, 02:32 AM
