586,754 active members*
7,522 visitors online*
    Jan 2011
    16
    Mori Seiki CL 20 turret won't index
    Greetings. I have a 1996 Mori Seiki CL 20 with a 10 station turret and fanuc 21tb control. The machine has had a turret index problem for a while when cold but after you index it a few times it worked fine. That problem was, the turret would operate normally but the TRCL light would stay off after index was complete. Then it would have the EX0357 turret index time over alarm. Seems like there was a B phase keeping signal off alarm occasionally.
    The problem now: I was running it yesterday and it went to do a tool change mid program and it alarmed out with a EX0357 turret index time over. The TRCL light was flashing. I cycled the power and now in manual, the TRCL light flashes and if you try to index, the turret extends to disengage, the TRCL light goes out but the turret does not rotate. After a few seconds, the TRCL and ERR starts flashing along with the EX057 alarm. At that point you can't move either axis or try to index again. After I power it down and back up, the turret pulls back in and you can try again and the axes move in manual. The only thing I can think of out of the ordinary was the hydraulic fluid was really low. Thank you in advance.
    Jan 2011
    16
    Re: Mori Seiki CL 20 turret won't index
    It was the relay that powers the turret motor.
  1. Mori seiki ZL25M10 lower turret index time out
    By FirstTimer2023 in forum Mori Seiki lathes
    Last Post: 11-03-2023, 10:35 AM
  2. Daewoo Puma 230M turret won't index
    By mrk_varga in forum Daewoo/Doosan
    Last Post: 01-26-2023, 06:22 PM
  3. Replies: 0
    Last Post: 03-31-2022, 12:08 PM
  4. Replies: 0
    Last Post: 02-03-2018, 07:05 PM
  5. Mori Seiki SL2 turret won't unclamp
    By jolulank in forum Fanuc
    Last Post: 02-13-2013, 08:51 PM
