587,383 active members*
3,476 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > parser: commanded z axis move to far possitive
    Nov 2007
    I have a bridgeport series 1 eztrak mill and I am getting the parser error for my z axis. I am new to machining and inherited this machine in a company takeover so I do not know if a repair is needed or what. Any help is appreciated.
    Nov 2004
    3028
    It means that based upon where zero is set on the Z axis, you are asking it to move further than it can.
    You must have a 3 axis TRAK. You probably have not set the TLO(tool length offset) or a tool and are commanding it to go .050 above zero which it cannot do since it is all the way up and at zero already.
    George
  1. What method did you use to move the x-y-z axis?
    By widgitmaster in forum Polls
    Last Post: 07-04-2013, 04:49 AM
  2. G91 B axis move?
    By DocHod in forum G-Code Programing
    Last Post: 11-02-2007, 05:56 AM
  3. Replies: 14
    Last Post: 01-08-2007, 06:10 AM
  4. ALARM!!! "Commanded X Axis move too far / Positive"
    By aimeahz in forum Bridgeport / Hardinge Mills
    Last Post: 04-20-2006, 11:51 PM
  5. Mach 1 x-axis will not move
    By Redline in forum Mach Software (ArtSoft software)
    Last Post: 07-05-2005, 06:01 AM
